Hello all
looking for anything you can share, not support or troubleshooting support of your stuff, so do not worry I won't pester with follow-up email, just the actual Vxe file.
Ideally something with quick buttons/panel but just a screen capture would be nice.
best I have found so far is a data pull to a file… not great requires post processing of said file.
Is there a way to print the screen like a plotter emulator?
Main application will be to process the "monitor output" of my 8903a but on some cases I will use the 3562a built-in signal source to feed the DUT too.
thanks
paba
thanks
paba
