Equipment & Tools From test equipment to hand tools
DIY programmable dual channel bench PSU 0-50V/3A
Old 26th November 2017, 01:26 PM   #201
prasimix is offline prasimix  Croatia
prasimix's Avatar
Default Foot pedal control
I've missed this for a long time, but now it's added: channel's output control using "third" hand or foot pedal, when nobody is around for assistance, etc.
Foot pedal control video
Old 1st May 2018, 10:07 AM   #202
prasimix's Avatar
Default Firmware v1.1 is released
Dear all, the firmware v1.1 is now released. But, this time it does not comes alone but accompanied with first milestone of EEZ studio. A first introduction how to use one of its modules is now available in separate thread here. More specific information how to use it to access EEZ H24005 I'll continue to post in this thread.
Two main feature of v1.1 are added file management for built-in SD card and internal data logger. In this version both of them are accessible only using SCPI commands, but don't worry a decent support to automate interaction with SD card and data logger is included in mentioned EEZ Studio.
Old 6th May 2018, 03:25 PM   #203
prasimix's Avatar
Default New video about firmware v1.1 main features
Preview of two main features added to firmware v1.1: SD card file management and internal data logging using SCPI commands. The EEZ Studio version M1 (its ESW module) is used for interaction with the EEZ H24005 (i.e. initiate data logging and exchange files).
YouTube
Old 7th May 2018, 03:35 PM   #204
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Hi. Can I use the latest firmware v1.1 with the first version pcb? Or isn't worth the upgrade?
SB
Old 7th May 2018, 03:37 PM   #205
prasimix's Avatar
SB
Yes, you can use it. Please check the release note to see is it worth the upgrade or not.
Old 6th June 2018, 01:12 AM   #206
IoTSteve is offline IoTSteve
Hello, I was looking at the crowdsupply site but could not figure out if this power supply is available for purchase. When will it be?
Stephen
Old 20th June 2018, 04:35 PM   #207
prasimix's Avatar
Stephen
No it is not, but hopefully something will happen to the end of this year .
DIY programmable dual channel bench PSU 0-50V/3AHide this!Advertise here!
DIY Dual Channel Active Tube Tone Control HideawayStudio Tubes / Valves 1 1st November 2010 01:05 PM
Good DIY Bench PSU for Solid State Gavinator68 Solid State 18 25th August 2008 05:33 PM
Programmable Bench Power Supply? samsagaz Parts 1 22nd January 2008 02:21 AM
Bench PSU sorenj07 Tubes / Valves 5 19th February 2007 10:53 PM
ESP project 3A amp at +/-50V Freddie Solid State 6 6th January 2002 02:54 AM
