Equipment & Tools From test equipment to hand tools
Accelerometer Testing of Loudspeaker Drivers
Old 16th December 2016, 09:47 PM   #31
gdan is offline gdan  Greece
The photo of the previous post.
Thanks Murilo!
Old 6th April 2017, 07:42 PM   #32
Another reminder for those that are interested to build the accelerometer amplifier.
More info here:
http://www.diyaudio.com/forums/swap-...plifier-2.html
Old 21st September 2017, 09:07 PM   #33
I have used the ACH accelerometer with its pre-amplifier to measure the distortion of a woofer and its peak displacement in relation to the input voltage.
I used the STEPS part of the ARTA software (STEPS Main Menu --> Record ---> Distortion vs. amplitude) with the output of my accelerometer amplifier (set to "Exc" to measure displacement) connected as an input to the software.
The accelerometer is attached to the center of the woofer's cone and the microphone very close to the cone.
In the attached photo you can see such a measurement of a 12" subwoofer placed in a box of about 30 litters.
File Type: jpg Cone Displacement measurements at 20 Hz.jpg (94.3 KB, 125 views)
Old 10th July 2018, 05:50 PM   #34
skn is offline skn  Denmark
Hi George,
Just to let you know.
The Accelerometer preamp. arrived this morning and everything looks fine.
And thanks for building the unit and doing the calibration.
Steffen
Old 11th July 2018, 01:53 PM   #35
Pano is offline Pano  United States
Pano's Avatar
Interesting graph. The displacement vs voltage looks very linear. Why is THD so high?
Take the Speaker Voltage Test!
Old 12th July 2018, 09:56 AM   #36
If you consider that the woofer is driven at 20 Hz by 15.5 Vrms (almost 44 V peak to peak) and the excursion is 14 mm peak to peak, I would say that a distortion of 10% is not so high.
Accelerometer Testing of Loudspeaker DriversHide this!Advertise here!
Accelerometer to audiointerface ELEFANTOMET Analog Line Level 0 28th September 2012 09:25 AM
Testing Drivers DC Sounds Equipment & Tools 1 13th February 2011 01:16 PM
Loudspeaker Testing Equipment bwhitejr Multi-Way 7 17th August 2007 06:50 PM
DIY Loudspeaker Testing Environment gregorx Multi-Way 14 13th July 2004 01:24 PM
Testing and Loudspeaker Design MarkMcK Multi-Way 0 1st September 2003 06:49 PM
