Equipment & Tools From test equipment to hand tools
Oscilloscope cost to generate & measure these traits
Old 22nd December 2014, 04:25 AM   #1
stephend1714 is offline stephend1714  United States
Default Oscilloscope cost to generate & measure these traits
UPFRONT ADMISSION : COMPLETE NEWBIE ABOUT THOSE INSTRUMENTS.
Please omit conjectures which say "there will be no audible difference", and that this is a silly total waste of time and money.
??? WHAT DIFFERENCES HAPPEN IN WIRE ??? ---
A. With a run of wire from amp to crossovers WITHOUT BINDING POSTS . In other words, WIRE ONLY -- no binding posts between.
B. With a run of wire from amp to crossovers WITH BINDING POSTS -- adding junctions to a path for the music signal.
Tests that seem revelatory for what I want to discover :
1.) Simultaneous 15K and 13K sinewaves -- intermod levels and odd-order artifacts.
2.) Simultaneous 5K and 3K sinewaves -- intermod levels and odd-order artifacts.
3.) Squarewaves at 15K / 10K / 5K.
4.) Step and impulse response at 15K / 10K / 5K.
So, what company has a scope to determine these factors ?
Old 22nd December 2014, 04:28 AM   #2
ahankinson is offline ahankinson  United Kingdom
AP High Performance Audio Analyzer & Audio Test Instruments : apx555
Good luck.
Old 22nd December 2014, 09:53 AM   #3
Kiriakos is offline Kiriakos  Greece
Banned
The analysis of the results of what any Test and Measurment equitment can do, comes from the training of the user it self.
Old 22nd December 2014, 10:08 AM   #4
On Hiatus
SY's Avatar
I would strongly suggest that you get a comfortable familiarity with metrology and instrumentation first. The pursuit of chimeras is an expensive and time-consuming activity, and without a great deal of experience and knowledge, one can easily believe that the chimera has been found without realizing that it was actually a stuffed Pooh Bear.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 22nd December 2014, 10:18 AM   #5
DF96 is offline DF96  England
A meter can give you a number. A scope or spectrum analyser can gve you a trace. These are raw data. To turn them into information you need to understand what is happening, and allow for confusing issues. The smaller the effect you are looking for the (relatively) larger are the confusing issues. Those who have never tried it may be surprised how easy it is to 'measure' some artifact of the test equipment and then proclaim it as a new discovery. It always helps, of course, if this artifact (at least in a dim light) looks vaguely like the effect you hoped to see.
Old 22nd December 2014, 11:46 AM   #6
Herewith is lobbed a sincere "thank you" to all 4 respondents above. Yes, wise counsel to become familiar with metrology, and so forth. I will sign off this thread, but of course read and consider any more responses . . .
Have a merry You-Know-What, and here's hoping you've balanced naughtiness with niceness so as to get at least a few presents. Geez -- 2015 in scantly more than another week ? Father Time must have put his rickshaw in 5th gear . . .
Old 22nd December 2014, 03:15 PM   #7
bear is offline bear
expert in tautology
bear's Avatar
Actually you asked about the differences in binding posts and related to that differences in connections and/or contacts.
For the latter there is some work that has been done on switches or relay contacts. This probably does not apply to binding posts, since those (with a wire inserted or a spade lug) are not point contacts, and are under considerable pressure.
It's truthfully really tough to test or measure any of this, especially in light of the reasonably lousy conductivity of solder... and tin plated steel leads in various components... etc.
Even so, I've been in situations where if asked to tell the truth and nothing but the truth I would say that it certainly appeared that one particular brand of binding post (and not an expensive boutique brand either) appeared to be imparting a nasty and unsual spatial quality to the sound. Replacing them appeared to resolve the problem. I had been prepared to rip the amp apart looking for a parts placement error, and thus a non-linearity. This by no means is dispositive, merely anecdotal.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 22nd December 2014, 08:59 PM   #8
I promised to sign off on this thread, but just letting the Scope Jockeys here know that the yummy APx555 (recommended as performing the stunts I have in mind) chimes in at a cool $28,300 list.
Buying one would mean that I don't eat for the next five years at least, so a thriftier alternative is mandatory .
Maybe this ham operator has something more reasonable gathering dust in his basement : EB5AGV's Test Equipment Collection
Notice that his motto is "A hobby all by itself". . .
Old 22nd December 2014, 09:12 PM   #9
expert in tautology
bear's Avatar
Nice antique stuff, I have some of those myself, btw. Also, he's not in the USA with the call sign EB5AGV... so, guess you need to take a different approach?
_-_-bear
Oscilloscope cost to generate & measure these traitsHide this!Advertise here!
Low cost LCD oscilloscope and DIY kit ray0812 Vendor's Bazaar 23 8th June 2014 10:36 PM
Desirable traits for nearfield/desktop setup Pallas Multi-Way 25 26th November 2013 01:21 PM
Can I directly measure 220V AC with a oscilloscope? Sunsun22 Equipment & Tools 17 5th October 2010 09:01 PM
Low-Cost USB Hobby Oscilloscope salesmonster Parts 7 20th November 2008 08:51 AM
Characteristics/Traits of Tube Amp speaker percy Multi-Way 2 14th December 2004 09:41 PM
