Equipment & Tools From test equipment to hand tools
Olson TE-209 Audio Generator, Sine and Square Wave
Old 20th July 2014, 08:46 PM   #1
Listen is offline Listen  United States
Listen's Avatar
Default Olson TE-209 Audio Generator, Sine and Square Wave
Does anyone know where I can find a schematic and/or manual for this unit?
Thanks,
John
Old 21st July 2014, 03:09 PM   #2
Listen's Avatar
I suspect that this audio generator may have been released under more than one brand/model name/number, so here is a picture to help identify it.
Thanks for any leads,
John
Old 22nd July 2014, 04:28 AM   #3
dchisholm is offline dchisholm  United States
dchisholm's Avatar
John,
I can't get your picture to display.
I am not familiar with that model by Olson. If I recall correctly, Olson was a bargain retailer of hobby electronics and hi-fi equipment. At the national level they were similar to Lafayette Radio, and Burstein-Applebee; there were also some regional competitors. I think they all disappeared in the early 1970's.
As you noted, it is not unusual for a basic design to be produced or marketed by several retailers. Sometimes the only differences are front-panel paint and markings; in other cases there may be minor changes in the circuitry. (I think there was a thread on this Forum last winter regarding an obscure VTVM, and the owner discovered that the example circuit published in the RCA Tube Manual for a dozen years or more was almost identical to his unit.)
Can you offer any additional clues about your generator? Approximate age? Tube or transistor? A view inside the case?
Dale
Old 22nd July 2014, 06:38 AM   #4
consort_ee_um is offline consort_ee_um  United Kingdom
My guess is that the oscillator is similar to the Lafayette TE-22. Manual including circuit diagram here:
http://bama.edebris.com/manuals/tech/te22
My blog:
Consort3's Blog | Just another WordPress.com weblog
Old 22nd July 2014, 03:16 PM   #5
Listen's Avatar
dchisholm: It is a tube unit--I'm sort of a tube guy. In any case, I will post more pics and some specs tomorrow.
consort_ee_um: Oh THAT looks interesting. Even if it is not an exact match, it may help me diagnose my model.
all: This is quite a well-made little audio generator. The problem I am chasing is this: Although it produces near perfect sine-wave output, it flat-lines when I flip the switch to square wave.
Thanks to all!
John
Old 23rd July 2014, 06:32 AM   #6
dchisholm's Avatar
Originally Posted by Listen View Post
dchisholm: It is a tube unit--I'm sort of a tube guy. In any case, I will post more pics and some specs tomorrow. . . .
I'll give you 50/50 odds the oscillator is a Wien bridge circuit, and probably quite similar to models by Heath and Eico from the 1950's and 60's. Schematics for those instruments should be readily available.
Dale
Old 23rd July 2014, 03:37 PM   #7
Listen's Avatar
Exactly correct, it is a Wien bridge and the Olson TE-209 appears to be an exact clone of the Lafayette TE-22.
Someone has rewired the heater circuit for v2 and replaced the 6AQ8 with a 12AT7. I hope to restore it the factory configuration and function tonight.
I suspect that v2 first clips one side and then the other of the sine wave to create the square wave output, so trouble shooting should be easy.
Thanks,
John
Old 24th July 2014, 02:34 AM   #8
Listen's Avatar
First, thanks to all. Got home and swapped in the correct tube after rewiring the heaters properly; still no square-wave output. Traced it back and realized that the square/sine switch was wired backward. Swapped two wires and voila! Checked the alignment and I suspect that it is running better than spec. In any case, after this unit warms up for a half hour or so, it is a nice, stable, accurate audio generator all across its bandwidth that will be a joy to have on the bench.
Best,
John
Olson TE-209 Audio Generator, Sine and Square WaveHide this!Advertise here!
Heathkit Sine/Square wave Generator Manual needed! Chris56000 Tubes / Valves 2 7th April 2012 04:39 PM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Sine and square wave function generator Bricolo Parts 14 7th March 2003 11:45 PM
