Equipment & Tools From test equipment to hand tools
Kind advice required for desoldering ?
Old 19th July 2014, 10:34 AM   #1
ginetto61 is offline ginetto61  Italy
Default Kind advice required for desoldering ?
i am desoldering parts with tiny leads on a unit with tiny traces
I am using a desoldering pump with mechanic action and i do not like it
What do you use ?
I am not looking for a complete desoldering station, that i would love by the way
Just a decent and not very expensive desoldering device
In this operation i risked to destroy some units ... it is even more delicate than soldering
Kind advice will be very much appreciated
Kind regards, gino
Old 19th July 2014, 10:42 AM   #2
ewollowe is offline ewollowe  Australia
Youtube is your friend
Have you tried solder braid/ solder wick?
Old 19th July 2014, 10:43 AM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Are you trying to rescue the components or repair a PCB ?
Old 19th July 2014, 11:14 AM   #4
Hi and thanks for the kind reply
I watched a video on youtube about this ... i did not like it
I like something like a real electric pump ... something very fast, very pro and very cheap
Ok .. i could make an effort for something very nice
I intend to desolder a real lot
Only for this preamp i have there are tenths of parts to be replaced
New caps, diodes ... and the traces are very delicate
Kind regards, gino
Old 19th July 2014, 11:19 AM   #5
Hi i am actually replacing 20 years old parts in a preamp with new and supposedly better components
They are very tiny diodes (1N4007 ... someone told me that they are not the best around and i have already bought UF4007 to replace them all)
and electrolytic caps ... about 20 years old
I am still undecided between Panasonic FC and Nichicon Gold as possible options for new caps.
I hope that at the end of the process the supply voltage would be less noisy
and the overall sound more transparent
Thanks a lot. Kind regards, gino
Old 19th July 2014, 11:24 AM   #6
So you are trying to repair a PCB.
Best way is to chop the component leaving long legs in the PCB. Then heat each leg and pull it out. This will be easier than trying to pull out the entire component.
Caps are a bit more tricky but I stay with the philosophy - f**k the component, save the board.
Old 19th July 2014, 11:57 AM   #7
Mooly's Avatar
Braid every time for me. And a hot iron with a large tip that can carry the heat.
http://www.diyaudio.com/forums/parts...sed-tools.html
Old 19th July 2014, 12:08 PM   #8
If you are using braid it needs to be fresh. Tarnished braid is useless.
Old 19th July 2014, 12:10 PM   #9
Mooly's Avatar
Can't say I've ever had a problem with braid tarnishing (as it should be heavily fluxed anyway which prevents tarnish). I'm still using stock I obtained over 15 years ago (Servisol brand) and its fine.
Old 19th July 2014, 12:14 PM   #10
I suppose it depends on the quality of it. I always end up cleaning it and applying fresh flux to get it to work. Flux will eventually tarnish the copper braid.
Kind advice required for desoldering ?Hide this!Advertise here!
A bit of DIY advice required john jones Headphone Systems 4 12th July 2012 07:52 AM
quad advice required johniss0001 Solid State 0 28th July 2008 11:14 PM
what kind of desoldering wick to buy? spooney Car Audio 1 26th September 2007 12:33 AM
Offset nulling - kind request of advice beppe61 Solid State 13 9th May 2007 12:47 PM
Phono input advice required Satboy Analogue Source 3 24th February 2007 06:02 AM
