Equipment & Tools From test equipment to hand tools
Recommend a USB audio for use with Windows 7 laptop
Old 21st June 2014, 03:09 PM   #1
JimT is offline JimT  Canada
Default Recommend a USB audio for use with Windows 7 laptop
I have finally retired my old Win XP laptop. Unfortunatly my E-MU 0202 does not work with the new Windows 7 laptop. Seems to be a problem with the driver and 64 bit Windows 7. I use this to listen to music and for testing when doing my occasional speaker designing and building. Please recommend a new USB audio device for me.
Jim
Old 21st June 2014, 03:49 PM   #2
madtecchy is offline madtecchy  England
TC electronics KONNEKT 6. Fantastic sound quality very nice to use also has balanced outputs .. only problem is it uses firewire interface
Old 21st June 2014, 04:22 PM   #3
I do not have firewire but looked at it just for fun. Nice but unfortunatly they do not have 64 drivers and then there is the problem of my laptop not having firewire ports.
I should probably point out that I do have a microphone preamp, so that is not important.
Jim
Old 21st June 2014, 07:53 PM   #4
euro21 is offline euro21  Hungary
Hi Jim,
Try 0202USB Win7 beta driver.
Creative Worldwide Support
Old 21st June 2014, 09:31 PM   #5
Originally Posted by euro21 View Post
Hi Jim,
I tried that awhile back it but this computer locks up when I try to play something. Strange as I'm sure that driver worked on my work computer a Windows 8 laptop, but it does not provide control over the bit level or sample rate. Still I can not get it to work at all on this one. Someone on another site complained about a different audio device not working on computers with USB 3 ports, perhaps I have a similar problem. I was thinking is was time to upgrade hopefully to something that has asio drivers. I am working on a list of devices to check out. Just starting so there will be a number of unacceptable devices on it, but here it is. Most of these do not provide data for distortion or noise. So far it seems like I may have to buy a desktop and get an M-Audio 192. Unfortunately my small shop does not have the space.
M-Audio M-Track Plus 24 bit 48 kHz $99
M-Audio M-Track Quad 24 bit 96 kHz $250
Avid Mbox 24 bit 96 kHz $299
Scarlett 2i2 24 bit 96 kHz $150
Scarlett 6i6 24 bit 96 kHz $350
Behringer FCA1616 24 bit 96 kHz $250
Steinberg UR22 24 bit 192 kHz $150
RME Fireface UFX 24 bit 192 kHz $2299
Sound Devices USBPre 2 24 bit 192 kHz $849
Jim
Old 21st June 2014, 10:05 PM   #6
The beta driver worked fine on my daughter's computer Windows 7 32 bit (USB 2 ports). It even allowed me to run it at 192 kHz. I am still looking looking for an upgrade but someone else may want to know this does work sometimes.
Jim
Old 21st June 2014, 10:48 PM   #7
AlanL is offline AlanL  United States
I'm using a Steinberg UR28M with win7, never had driver issues.
Old 21st June 2014, 10:51 PM   #8
1audio is offline 1audio  United States
I am using a Tracker Pre with the same beta driver on a win 8.1 dell xps12. I had problems with the older USB3 ports. This generation does not have those problems with USB3 ports. I think its a combination of better hardware and software.
If the Win 7 laptop has a USB 2 only port that might work. (The USB 3 ports are blue)
Demian Martin
Product Design Services
Old 21st June 2014, 11:08 PM   #9
USB 3.0 was the problem. This Thinkpad T440s has all USB 3.0 ports, but I was able to "downgrade" this to USB 2.0 in the BIOS. Works fine now. These are Intel chips on the USB so hopefully Intel fixes this in future driver updates. Now I just have to remember to "upgrade" when I need the faster USB 3.0 for my external drives.
Jim
Old 21st June 2014, 11:33 PM   #10
Jim
Hi JimT im running it on 64 bit drivers. it works a treat I like having analogue stereo line input too . to me it is my dac come pre amp . Ps It leaves the Maudio gear for dead on sound quality and musicality I used to own some maudio till I stumbled on this KoneKT 6 . It really is a shame TCelectronics do not support usb interface
Recommend a USB audio for use with Windows 7 laptopHide this!Advertise here!
State of Windows USB audio drivers? gmarsh Digital Source 0 9th November 2012 02:35 PM
How to provide EQ for my laptop with a USB DAC sprinter Digital Line Level 6 23rd April 2011 04:05 PM
Recommend a portable USB DAC? EC8010 Digital Line Level 12 24th January 2010 06:13 AM
Laptop--Vista--USB Dac SamClassA Digital Source 4 12th May 2008 12:00 PM
USB soundcard for laptop 24bit with resampling Jonasa Digital Source 12 16th September 2007 06:39 PM
Copyright ©1999-2017 diyAudio
