Equipment & Tools From test equipment to hand tools
How to interpret measurement spectrum graphs and peaks
Old 11th May 2014, 10:11 PM   #1
maxw is offline maxw  United Kingdom
maxw's Avatar
Default How to interpret measurement spectrum graphs and peaks
I'm reasonably new to using to taking measurements and I was wondering if someone could help me out with some aspects of interpreting the results, particularly the spectrum graphs and their peaks.
First of all, why do a lot of graphs have a large peak in the middle? Arta does this but RMAA graphs don't. Eg:
Some of my noise graphs in RMAA have a peak at 50hz, even when the mains isn't connected to my device. Any idea why?
Sometimes I get large peaks at 50hz and then at 150/250/350/450 etc. What would cause this?
Any advice appreciated!
Old 11th May 2014, 10:48 PM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
This could be from a couple of things. Firstly it could be mains ripple from inadequate smoothing of the rectified supply. Secondly it could be leaked flux from a mains transformer coupling into signal wires.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 11th May 2014, 11:26 PM   #3
davada is offline davada  Canada
In the first graph the large peak in the middle in the source fundamental. If you use sat a 1kHz tone then the fft will display this as a peak at 1kHz. Because the fundamental has the greatest power it will stand much taller than the other peaks. The other peaks are mostly harmonics of the fundamental tone at 2kHz, 3kHz, 4kHz and so on. If a very pure tone is used, one having few harmonics or very low in harmonic power, then beyond what the harmonics the tone generates is the harmonic contribution of whatever DUT, device under test, is contributing. This is a very overly simplistic explanation but it should give you an idea of what your seeing.
What I see in the third graph is the mains fundamental and it's harmonics. I think you've noticed the peaks are multiples of the 50Hz which mean they are harmonics of the 50hz.
The peaks at the upper end of the graph are something else.
David.
Old 11th May 2014, 11:27 PM   #4
EssB is offline EssB  United Kingdom
The peak in the middle of the ARTA spectrum is a 1KHz signal.
Do you have ARTA's internal sine generator enabled ? Check that the 'Gen' dropdown box (just below left of the toolbar) is set to 'External'.
Old 11th May 2014, 11:48 PM   #5
kouiky is offline kouiky  United States
kouiky's Avatar
From what I have read on this site and the advice that I have received through PM from very respected members ( you know who you are), RMAA is a bit, well, sloppy. And, it's quite limited in its accuracy that is compounded by the audio interface, which is why lab grade equipment costs tens of thousands of dollars compared to hobby usb analyzers.
Seeing that the noise is harmonically related to 50Hz AC, there is a chance that the dongle is likely picking up some power supply noise. With low-cost audio analyzers, both the test bandwidth and upper limits are restricted to preserve some integrity. The noise seen in the upper limit may be related to the carrier tome that the close modulates at, or may be something simpler. I have a few ideas about it.
Old 13th May 2014, 11:10 AM   #6
maxw's Avatar
Thanks for the reply everyone.
In the third graph there is mains connected so that 50hz peak is probably that. But in the second graph there is also a 50hz peak when there is no mains connected to the DUT?
Does that mean I can safely say that the those 2/3/4Khz peaks are not caused by the DUT? And ignore them?
Yes. If I set it to external then I need another device to generate the test signal, right?
Old 13th May 2014, 12:00 PM   #7
On Hiatus
SY's Avatar
No and no. You have to do some work baselining your test, then get an idea of repeatability. Once you've got that nailed, you can separate DUT distortion from test distortion.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th May 2014, 05:59 PM   #8
... in the second graph there is also a 50hz peak when there is no mains connected to the DUT?
Still mains related pickup from somewhere. It can be difficult to get rid of. Try to keep DUT and connection leads away from powered items, or turn them off. You can get it down to a certain level but then you find it varies by time of day, the neighbour's washing machine, aliens tunneling, etc. Actually -120dB for a quick test hookup is not so bad, I've had worse.
ARTA has a high pass filter you can set to exclude most of the mains related junk from the THD measurements.
Yes.
Old 13th May 2014, 06:21 PM   #9
maxw's Avatar
Thanks! I've adjusted a few wires and got it down to -138dB now.
Yes, I've done loopback tests as a baseline and these peaks are there too
Old 13th May 2014, 06:42 PM   #10
I think you can benefit from reading this thread.
http://www.diyaudio.com/forums/equip...scillator.html
The thread has been running for years and it's hugely long but well worth the read. Every means of measuring TH distortion have been discussed and a few enhancements for SC - FFT measurements evaluated. It's all there. It would be redundant to discuss it here.
David.
How to interpret measurement spectrum graphs and peaksHide this!Advertise here!
How to interpret reverse null? Jay_WJ Multi-Way 29 24th April 2017 11:27 PM
Please help interpret my frequency response curve lowpoke Multi-Way 5 6th April 2013 08:28 AM
Help interpret graphs? markusA Full Range 22 10th May 2010 03:54 PM
PSUD - How do interpret the results? bluegti Tubes / Valves 8 13th May 2009 05:00 PM
Spectrum Analysis Spectrum of JX92s keladrin Full Range 2 26th May 2006 02:10 PM
Copyright ©1999-2017 diyAudio
