Equipment & Tools From test equipment to hand tools
Low Frequency Analog and Digital Signal Generator
Old 5th March 2014, 06:32 AM   #11
1audio is offline 1audio  United States
Originally Posted by altor View Post
DSD Bus and I2S But shares the same output connector's pins:
WCLK = L
SDATA = R
BCLK = CLK
In the development.
Device's firmware is easy upgradable from the USB-stick (disk on key)
Are you planning or already set up with a modulatable master clock for the jitter reduction testing?
What is not included in the DIY board kit? It seems to not include the DAC board. Are all the other essential parts included in the PCB kits, including the display?
Demian Martin
Product Design Services
Old 5th March 2014, 11:27 AM   #12
altor is offline altor  Israel
It is not possible in the current HW, but it is possible to use external 512Fs or 1024Fs clock.
It is simpler to say "what included"
JKGEN Kit - is what you see on a photo.
JKGEN DIY Kit - initially, there are 3 bare PCB (CPU, Output, Front Panel) plus asembled Clock Module.
And only 3 non assembled (used should solder) components:
- CPU with the necessary software inside (bootloader + firmware ),
- Display,
- Encoder.
All other components (including the cables) the user should buy and solder by himself. But I'm flexible to make custom order, and to add some other components (except R and C) with or without additional money (depends which components).
Most comonents that I use are from Mouser and DK.
DAC board includes - "Output".
Full device consicts of 4 molules:
1) CPU Board,
2) Clock Module
3) Output Module (I2S Buffer, DAC and TOSLINK)
4) Front Panel.
Here on a photo you can see all set.
Output Module is old version, with one minor mistake, now ther is a new version.
Front Panel can be or with 3 pushbuttons or with encoder. At photo - with buttons.
(Don't pay attantion to the IR receiver at Front Panel Module and free component places at tha main board - these modules are also used at another product, Jitter Killer).
Regards, Alex
www.altor.co
Old 7th March 2014, 09:29 PM   #13
This is the current version of User Manual. (DSD Mode is not mentioned yet).
You can find more detailed description, also scope and spectrum screenshots.
Regards, Alex
www.altor.co
Old 8th March 2014, 03:20 AM   #14
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Hi Altor,
I will buy one from you. How/price?
Manual for Jitter Killer - is it available?... can you download it to here?
THx-RNMarsh
Old 9th March 2014, 10:41 AM   #15
Originally Posted by RNMarsh View Post
Hi Altor,
Check the PM.
THx-RNMarsh
I will finish the english version in a few hours.
Regards, Alex
www.altor.co
Old 9th March 2014, 04:13 PM   #16
This is Jitter Killer description and the small article.
Regards, Alex
www.altor.co
Old 26th March 2014, 05:51 AM   #17
I got the generator todat and already used it for a few measurements; http://www.diyaudio.com/forums/loung...ml#post3868679 . I think its even better than it sounds from the description. I have a few quibbles with the UI I'll review with Altor and I'll post some measurements from it in a few days. In combination with a good audio analyzer its a really powerful solution. This is similar Digirator DR2 - Digital Audio Signal Generator but its $1800 and has a lot of features that most will never need.
Demian Martin
Old 26th March 2014, 11:56 AM   #18
Max Headroom is online now Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Ok, that is really encouraging news, and I/we await your detailed appraisal.
Kudos to Alto.
Dan.
Old 15th April 2014, 12:38 AM   #19
I just got another firmware upgrade. Alex has added Jtest to the suite and the UI is proving pretty quick and easy to use now. I'll try to post some measurements from this box later this week.
So far I can say that anyone developing a DAC product should have one. You can do many of the tests with other stuff but not as conveniently and some of the tests are almost impossible to duplicate.
Demian Martin
Old 16th April 2014, 09:40 AM   #20
Thank you, Damien.
Waiting for your measurements.
Regards, Alex
www.altor.co
Low Frequency Analog and Digital Signal GeneratorHide this!Advertise here!
Kramer Tools Model 830 Digital/Analog Generator ungie Swap Meet 8 12th March 2017 07:08 PM
Digital Audio Signal Generator prairiemystic Digital Line Level 3 23rd April 2010 09:47 AM
Low Distortion Signal Generator EchoWars Everything Else 150 6th March 2010 02:56 PM
Digital Freqency To Analog Frequency dswiston Everything Else 1 1st December 2004 03:21 AM
low frequency generator computer software? player_low Parts 3 30th October 2004 05:16 AM
Copyright ©1999-2017 diyAudio
