Equipment & Tools From test equipment to hand tools
Pomona 5519A Test Leads
Old 8th January 2014, 03:25 AM   #11
DJDestiny is offline DJDestiny  Singapore
Originally Posted by PedroDaGr8 View Post
I haven't had any major issues with Chinese leads. Some are better than others, that being said the feel of these leads blows all of the others out of the water. The silicone cable makes a huge difference in usability. I would imagine that to get a silicone test lead from China it would be much higher than $4. Which at that point why not but the Pomona leads.
About where I am, that very pomona lead costs 40$ (Holy ****) and a silicone cable from china costs about 6$
Old 8th January 2014, 04:28 AM   #12
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Look also for Brymen Silicone Gold Plated Test Leads on ebay.
Old 10th January 2014, 03:44 PM   #13
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Online at:
FRYS.com | Fluke
Kevin
Old 10th January 2014, 08:27 PM   #14
PedroDaGr8 is offline PedroDaGr8  United States
PedroDaGr8's Avatar
I love Brymen stuff these are likely quite good as well. The main seller on ebay is a guy named Frank Tong is highly thought of on EEVBlog, he posts there under the name "iloveelectronics". His shop 99cent Hobbies (sellername is f-t-2000) is often recommended. He sources a lot of good stuff and then sells it from Hong Kong (where shipping is much faster than China Post).
Old 11th January 2014, 04:10 AM   #15
mikeford is offline mikeford  United States
Originally Posted by Speedskater View Post
Online at:
FRYS.com*|*Fluke
Had them in my hands on Thursday along with a set of double ended shrouded leads. Price mistake/ stocked on wrong peg, so the price on the second set was $13 instead of $8 on the shelf, irked me so I didn't buy either one.
I'm back to looking at Ebay and cheaper cables.
Old 11th January 2014, 06:56 AM   #16
Salas's Avatar
I got TL175 on my 87V but I ordered the Brymen for the other DMMs. Pomona are great value at $13 if living in the U.S. Small things like heavy tangling leads can be an annoyance on the bench when much stuff is deployed during tests. Silicone leads are a world apart vs. normal ones. I especially dislike the mechanical memory of the lesser leads.
Old 11th January 2014, 08:58 PM   #17
I just ordered a pair of premium leads with alligator clips for $5.50 shipped from HK. Couple times a year I make it to one of the big regional hamfests (started by radio amateur groups 50 years ago, now a mix of computer stuff in a swap meet setting, but still free for non business radio hams), and they often have all sorts of cheap used test gear.
Old 24th January 2014, 02:38 PM   #18
Leads arrived, not as flexible as silicone, but seem to work just fine. Insulated alligator clips snap on to probe tips via a small dip on the probe tip that retains them. Solid feel to the meter connection, but the shroud is same flex material as the wire, so its soft, but again seems to work fine.
Old 24th January 2014, 02:59 PM   #19
lanchile is offline lanchile  United States
lanchile's Avatar
I have the same set up:Fluke 87v with TL175 and in my Fluke 27FM(military version) I have the Pomona leads and to be honest...I like the Pomona better. yeah you can call me crazy for saying that But the Pomona feel much better and yes, the Pomona is owned by Fluke
if you press hard on the "shrouded" part where you connect the to input meter you will see and feel that on the TL175 is solid and can brake...but in the other hand the Pomona are way more flexible and will not brake as easily as the TL175.
You can see my short review here: http://www.diyaudio.com/forums/equip...st-probes.html
Make it simple...Make it better!
Old 24th January 2014, 03:46 PM   #20
ilardi is offline ilardi  United States
The Pomona 5898 leads seem almost identical to the 5519A leads except that the 5898 uses stainless steel and 5519A uses nickel plated Beryllium Copper for the probe tips. I would imagine the copper has lower resistance but the stainless is probably more durable.
Are there other differences I am missing? What would be the advantage of one over the other?
Terry
Pomona 5519A Test LeadsHide this!Advertise here!
Test Signal for max power test of Class D? eem2am Class D 19 27th August 2012 09:22 AM
Transformer leads 454Casull Parts 4 16th September 2009 03:07 PM
Steel Leads and Tinned Copper Leads impsick Parts 0 19th April 2009 10:01 AM
Multimeter test leads? sneakers563 Equipment & Tools 4 2nd September 2008 03:50 AM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
