Equipment & Tools From test equipment to hand tools
Eico 221 VTVM Reguild
Old 23rd October 2013, 11:24 AM   #1
jblmar is offline jblmar  United States
Default Eico 221 VTVM Reguild
Greetings,
Bought an Eico 221 a couple weeks ago. It appears to be very accurate on DCV & Ohms. Haven't checked ACV yet. The set has held it's calibration well.
Of the 4 capacitors in the meter only the filter cap (2 uF) appears to be original. I plan to replace it with a Nichicon 10 uF 450 V Electrolytic. No need to change the others.
I plan to check all resistor values as there are quite a few 10% carbon composites as well as 2W composites. I don't know if they are original but I'm sure they have been there a while and are most likely out of spec. After all the meter is signed and dated '1951'. There are also a few 5% carbon resistors that look new. I'll replace them with 1% as well.
The DC & AC specs of the meter are 3% & 5% so the 1% resistors may be overkill, but I still like the idea.
I would like to gut the meter and replace all the resistors with 1% metal film. Perhaps the RNxxx type. These were used in the Sound Technology gear I have and are very stable over time.
I understand this meter is from 1951 and it's a piece of our hobbies history, but since new VTVMs are not available I would like to have this VTVM as accurate as possible for a long time of audio repairs both tube and solid state.
Any other resistor suggestions? I'm set on 1% Metal Films.
Old 23rd October 2013, 11:45 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
You would be well advised to use the original values and types.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 23rd October 2013, 12:05 PM   #3
Thanks, Jon.
That's the type of answer I was fishing for since I'm new to VTVMs.
Since everything checks out O.K. I may just replace the original Filter Cap and check resistor values. The older ones I'll replace even if they measure within spec.
Do you advise cleaning the Pots with CRC QD Contact Cleaner or leave them alone as they appear to be good.
Keep sending your opinions.
Old 23rd October 2013, 12:12 PM   #4
DUG is offline DUG  Canada
"If it is not broken, don't fix it."
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 23rd October 2013, 12:14 PM   #5
Agreed. I was trying to 'improve' it.
Old 23rd October 2013, 12:24 PM   #6
Any opinions to the contrary?
Old 23rd October 2013, 01:33 PM   #7
So the 1% Metal Film Resistor idea is out?
Old 23rd October 2013, 03:40 PM   #8
Some history on this VTVM. I bought it from an AK member who lives down in Florida. Given the high humidity there, my guess is that moisture has caused most of the 60 year old resistors to drift. I'm not looking to play with the meter just to maintain it.
Eico 221 VTVM ReguildHide this!Advertise here!
Eico 221 VTVM Probes jblmar Equipment & Tools 6 10th October 2013 10:31 PM
Ic 221-241 ?? rodolfo Solid State 8 2nd March 2013 07:38 AM
Eico NOS Mdl 232K VTVM Peak-to-Peak VTVM KIT UNOPENED HolySmokes Swap Meet 0 27th January 2012 10:01 PM
Danley TH-221 drawings ? matsj Subwoofers 37 23rd January 2012 10:04 PM
Eico 221 Voltmeter jdeitch11 Swap Meet 0 22nd February 2011 07:35 PM
Copyright ©1999-2017 diyAudio
