Equipment & Tools From test equipment to hand tools
Solder issues
Solder issues
Old 23rd September 2013, 03:57 AM   #11
Einric is offline Einric  United States
Einric's Avatar
Percy Audio sells Cardas Quad Eutectic for the best price I've found, It has Lead Tin Silver and Copper.
Old 23rd September 2013, 10:51 AM   #12
Does any other firm make quad eutectic?
I tried googling and found nothing else.
regards Andrew T.
Old 25th September 2013, 10:01 PM   #13
Einric's Avatar
Not that I know of.....I REALLY like the Cardas Quad, I have not tried the Cardas Tri-Eutectic without lead and I may try that some day.
It may just be the special flux core that makes it work so well.
I would say Kester 44 63/37 is a close second for useability but the Cardas Quad makes much nicer looking joints and it melts @ 338F just as the specs say.
I have a Pace Process Control Station and I verified the temperature.
Old 25th September 2013, 10:16 PM   #14
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Solder issues
Originally Posted by ashok View Post
The solder he is using will not melt or stick to the solder on the board.
Any solution to this ?
if it doesn't melt, how can it 'stick' to anything
it is difficult to melt existing/old soldering without any melted solder on your tip
I have experienced this once, with a completely burned out tip
and that may happen if you forget your iron with power on
with some luck you may be able to 'relive' your tip by rubbing in repeatedly on copper wire, with solder
keep doing it until the solder begins to stick to the tip
or your iron heating element may be gone
sometimes we know very little, and sometimes we know too much
Solder issuesHide this!Advertise here!
In need to solder!! canonnica Solid State 16 23rd June 2011 02:54 AM
Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? mbl Analogue Source 23 24th November 2010 03:13 PM
Best solder to use rtarbell Parts 4 20th November 2005 01:05 AM
what solder should be used ?? kambule Parts 27 8th August 2005 01:16 PM
Solder again Christer Parts 13 6th December 2002 12:48 PM
