Equipment & Tools From test equipment to hand tools
what do you use to hold the pcb when soldering?
Old 2nd September 2013, 10:49 PM   #1
mekanoplastik is offline mekanoplastik
Default what do you use to hold the pcb when soldering?
just wondering what type of suports or stands are most commonly used at hobby level, I am looking on builing my own mechanism to hold pcbs so references, requierements and ideas are welcome.
Old 2nd September 2013, 10:55 PM   #2
Oliphant is offline Oliphant  New Zealand
One of these
Old 2nd September 2013, 10:57 PM   #3
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Depending upon the size of the board something like this is pretty common.
PanaVise Circuit Board Holders for less at Howard Electronic Instruments, Inc.
Not an endorsement of the seller or the particular holder - just intended as an example. Let the internet be your friend and look around. A good magnifier glass is a big aid too.
HEI Magnifying Work lights with optional 3 or 5 diopter lens and fluorescent bulb.
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 2nd September 2013, 11:05 PM   #4
Originally Posted by Oliphant View Post
One of these
I have one just like that, but i always manage to tip it over ..i guess i could add a flat piece of board and glue the base but then, the little clips scratch the boards...i am not really fond of this design. Thank you for the refference.
those look very nicely made, board size will not be bigger than 20x20cm ...
Old 3rd September 2013, 01:00 AM   #5
mickeymoose is offline mickeymoose  Canada
I use the PCSS/2 http://www.mikrocontroller.net/attac...57741/pcss.pdf . Out of line, $wise, for hobby work, but a Xmas present to self? E
Old 3rd September 2013, 07:18 PM   #6
dangus is offline dangus  Canada
I often just use green masking tape to hold components in place.
I've used a PCSS holder, but the foam doesn't do a great job of holding small components flat on the board.
Old 3rd September 2013, 07:28 PM   #7
I have access to this monstruosity, which i is great for large pcb's or large production...it looks similar to the PCSS you mention, bit it is way too big for my needs.
I want to make a simple diy solution, as an exercise of design and fun...so I am looking for inspiration
Old 3rd September 2013, 07:35 PM   #8
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
for smaller boards I like to use a small multiangle hobby vice
but also have one like shown in post2
don't need anything for bigger boards
when soldering bigger caps I sometimes use the caps to 'carry' the board on the table
and level it with whatever matches
I would certainly like to have one of those stand mounted magnifier
sometimes we know very little, and sometimes we know too much
Old 3rd September 2013, 08:02 PM   #9
pilli is offline pilli  France
...gravity and the other fingers!
Three go for the soldering iron,
two for the solder,
you have five left.
That a hand's worth
(although both thumbs are taken).
Just joking.
Not recommended.
But my guitar playing technique got better
_
Old 4th September 2013, 03:56 AM   #10
I also tend to use electrical tape to hold components neatly against the board as I solder them in place.
what do you use to hold the pcb when soldering?Hide this!Advertise here!
PCB for TAS5630 Should be ok for hand soldering Yoshy Class D 3 1st June 2011 03:19 AM
Soldering tubes directly to PCB? thomsva Tubes / Valves 18 9th January 2008 07:12 PM
soldering parts to PCB spendorspain Parts 8 22nd April 2006 04:05 AM
Soldering temperature for PCB? jholtz Digital Source 4 6th June 2005 09:18 AM
