Equipment & Tools From test equipment to hand tools
what do you use to hold the pcb when soldering?
Old 4th September 2013, 10:34 PM   #21
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I don't have anything fancy. I've used a pair of pliers held closed with a rubber band.
I have a third hand like the one in post #2. I used some rubber tubing slid over the jaws to protect the work from scratches.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 4th September 2013, 10:56 PM   #22
tuo is offline tuo  Finland
I also use Panavise, namely this one:
Invalid Request
I bolted it down to a piece of wood and glued a little pieces of rubber mat (actually the thing that's left of those self adhesive little rubber feet after use) on each corner on the underside of the wood piece. Now I can move the vice away when needed, but it won't slide on the table.
Old 5th September 2013, 04:15 AM   #23
gmphadte is offline gmphadte  India
I found that soldering two wire ends is difficult with bare hands. Nowadays, I wrap a single strand wire on the joint and then solder it.
Gajanan Phadte
Edit:I am getting an itch to construct the TVIs wooden support at post #14
Old 5th September 2013, 05:12 AM   #24
Absconditus is offline Absconditus  Australia
Banned
I now wish that third arm wasn't removed at birth.
I do use a small bench vise but the jaw spread isn't usually enough. Normally, I muck around so much it annoys the tripe out of me.
Old 6th September 2013, 12:05 AM   #25
dangus is offline dangus  Canada
I'll use a Panavise board holder if I'm desoldering and need to use a soldering iron on one side of the board and a solder sucker on the other side.
A "third hand" is invaluable for soldering connectors. A bead of RTV (silicone) on the cast base stops it from sliding around on the workbench.
Old 9th September 2013, 07:54 AM   #26
amc184 is offline amc184  New Zealand
amc184's Avatar
I also use a PCSS2, it works great, though mine could do with new foam.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 9th September 2013, 08:33 AM   #27
Deafer is offline Deafer
Default alligator clip pcb holder
[QUOTE=mekanoplastik;3617921]I have one just like that, but i always manage to tip it over ..i guess i could add a flat piece of board and glue the base but then, the little clips scratch the boards...i am not really fond of this design. I put short lengths of heat shrink tube over the clip jaws - it stops the scratching, but it doesn't stop the whole thing from tipping over! I think I'll copy your idea and glue a board on he base to increase the footprint.
Old 12th September 2013, 01:08 AM   #28
crispycircuit is offline crispycircuit  United States
I use painters tape & small steel blocks to hold things in place. I also knock off the back pole piece of blown speakers for weights and knock off the maqnet which holds all the screws when repairing. A good set of reading glassses help. Of course I'm reading this thread to see what everybody else is doing.... I don't have any local soldering buddies...
The stuff you don't know always humbles us.........
Old 12th September 2013, 01:27 AM   #29
DUG is offline DUG  Canada
I made a clamp for the TDA3116.
Other surface mount parts are small enough so the board does not need holding.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 12th September 2013, 07:49 PM   #30
mekanoplastik is offline mekanoplastik
This is my first attempt, still have to improve couple of things..
what do you use to hold the pcb when soldering?Hide this!Advertise here!
PCB for TAS5630 Should be ok for hand soldering Yoshy Class D 3 1st June 2011 03:19 AM
Soldering tubes directly to PCB? thomsva Tubes / Valves 18 9th January 2008 07:12 PM
soldering parts to PCB spendorspain Parts 8 22nd April 2006 04:05 AM
Soldering temperature for PCB? jholtz Digital Source 4 6th June 2005 09:18 AM
