Equipment & Tools From test equipment to hand tools
Replacing Hitachi 222 scope
Old 31st August 2013, 10:49 PM   #11
jcx is offline jcx  United States
EEVblog #451 - Rigol DS1052E vs DS2072 Oscilloscope - YouTube will make you want to bust your budget - but also shows the cheaper Rigol in action
Old 1st September 2013, 04:43 PM   #12
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Columbus, Ohio has the nearby Dayton HamVention with it's endless booths of test equipment and parts. With both Inside Exhibitors and Flea Market Vendors plus 24,500 visitors.
Dayton Hamvention 2013 - DX Hamvention
Kevin
Old 2nd September 2013, 04:18 AM   #13
Jsixis is offline Jsixis  United States
I was at the Hamfest in 95, I keep missing the dates since then.
Back then I was there showing off Amiga computers, I had a CD32 that was running a little animation called Windows 95 Release
Old 14th September 2013, 08:23 AM   #14
geraldfryjr is offline geraldfryjr  United States
Hi There,
I went to use my V-425 scope today and it glitched out again!!!
This time it powered up just fine and after about 10 minutes it collapsed to a unfocused dot in the middle of the screen of about 1/4" diameter.
I tapped on the case very hard and it popped back in a couple of times but only for a few seconds and then glitched out again.
So I took the top off and started wiggling all of the connectors.
I found that the Main power cable PCB connector from the transformer on the board to be the culprit!!!
Some how the solder connection on the +/- 8Vac supply had cracked and broken loose!
I have seen such things before, But I still find it odd as the thing had rarely ever been apart and I have never taken any of the connectors off before.
All I have ever done to it was to spray down its occasionally noisy switch's and controls.
Upon re-soldering the connector all is well now and I expect this thing to outlast me!!! He,he,he,he
This scope is identical to the 225 only it is the 40Mhz version.
Here are some pictures to show where the issue had occurred.
Sorry, But I didn't get in pic's of the faulty display.
jer
Replacing Hitachi 222 scopeHide this!Advertise here!
Hitachi V-121 O-scope - basic usage... GlidingDutchman Equipment & Tools 1 25th July 2008 08:41 PM
Hitachi v-202 scope Altecboy Equipment & Tools 8 13th December 2007 10:57 PM
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 10:59 PM
need hitachi v-152f scope manual lndm Equipment & Tools 2 9th March 2006 03:45 PM
FREE: 15 MHz Hitachi 0-scope BDP Swap Meet 3 12th June 2005 11:32 PM
