Equipment & Tools From test equipment to hand tools
Audio Precision AP Analyser series
Old 8th August 2013, 08:55 AM   #11
RNMarsh is online now RNMarsh  United States
RNMarsh's Avatar
I am still waiting for the IMD option to arrive and then I'll install it and start to get the A-P 2722 up and running..... -RM
Old 9th August 2013, 01:23 AM   #12
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I sent mine to AP for a fixup and went on vacation while they installed it -- came back quickly.
Old 9th August 2013, 01:39 AM   #13
Loudthud is offline Loudthud  United States
Loudthud's Avatar
Can anyone describe the Compute > Linearize function?
Measuring a preamp or power amp and plotting output level (dBV) as a function of input level (mV) you get a sloping line. Use the Compute > Linearize function and you get a somewhat flat line that I think represents gain but there can be a one or two dB error. The graph below shows output vs input after the Linearize function (cyan) and in red I plotted numbers taken directly from the Sys 1's generator and analyzer. A small spreadsheet was used to do the math. It was suggested to me that the units for the output be set to dBg (dB in reference to the generator) which seems to plot more like what I would expect, and you get the gain in dB.
Old 9th August 2013, 02:41 AM   #14
jackinnj's Avatar
See page 474 of the User's Manual.
When using analog sweep, use the bandpass filter and set the detector to anything but 'auto'
Old 13th August 2013, 01:33 AM   #15
RNMarsh's Avatar
Well the IMD option boards just arrived today. new software and hardware and learning curve will keep me entertained for awhile. Soon, I hope to be able to characterize the ADC soundcards and QA400 et al for thier accuracy and quirkiness with harmonics below -100db.
Ultra-low distortion signal source/generator and then measuring it has been a long road here for me. It looks like i have close to what I need now.... with the ShibaSoku and the new A-P2722. I will find their limits and push them.
30-40 years ago I was at the 339A limit for measuring amp distortion.... .0018% THD. Had to give up trying to measure it at that time and actually just went on to do other things. Now we can meaure better and I have the time back again to see what can be done on a second Go-Around.
Then, we can start to make fabulous CFAmps and distortion cancelling cicuits with assurance that the tests are accurately telling us what the DUT is doing.....
[Phew! Glad I'm doing this while i am still young and have the stamana and energy for it.] :-)
Thx-RNMarsh
Old 14th August 2013, 06:21 PM   #16
RNMarsh's Avatar
The software doesnt run on my new i7. Got to call them. maybe its the USB3.0? or new WIN? but software runs the A-P with my 10+ year old WINXT . What ever happened to the idea of P-N-Play when you really need it to work? Jeez.
-RNM
Old 14th August 2013, 06:59 PM   #17
1audio is offline 1audio  United States
You may need to run it in administrator mode. Also 32 bit vs. 64 bit? Run in compatibility mode for XP?
It seems there are three generations of software for three distinct product generations. The system one, the 22/27 series and the new digital variations. The new box is really a soundcard with autoranging inputs. Its good (-110 or better loopback harmonics) but not 27 series distortion. They consider it a bargain at $6K, $11K with all the software. However a tweaked emu 1616m could have the same performance and used with something like ARTA or HPworks get the same results. (I find the mixer for the EMU really difficult but that's me.)
Demian Martin
Product Design Services
Old 15th August 2013, 03:52 AM   #18
RNMarsh's Avatar
You are correct.... all those things PLUS it wont work on WIN 8 unless I go to thier site and find another piece of software to download (patch?). But even so the expensive Dolby option wont work yet with WIN8. [not that i need that option... but really..... for the price?]
A 6K sound card? Wow. -110dB? ... not so Wow. Not including software? Underwhelmed.
That brings me to an interesting observation today.... while using the old XT-Pro system for the 2722... I plugged the ShibaSoku generator into the 2722. No 2H or 3H seen ?!? Both ShibaSoku's are a bit high by current standards on the noise..... I complained about it with the 725 analyzer and wanted to clean it up some with new, low noise opa in the filters and analog outputs to the monitor port. The gen is similar but Ok at -130dB re 1v ref on the FFT from the A-P 2722. I'll be able to verify more closely and get a better handle on it once i get the 2722 running on the new i7 PC. I sure hope I dont end up with three systems and three very different results.
-Richard
Old 16th August 2013, 05:21 AM   #19
RNMarsh's Avatar
Default Variations in Harmonic measurement levels --
Getting no-where fast with the A-P 2722 software. No time for this.... calling A-P Tech support to hold my hand..... WIN 8 plus a new A-P... both software to learn at the same time (?).
But, I did some other tests today - regarding the levels of harmonics.
First is the ShibaSoku 725D. it shows the 2H from the ShibaSoku generator as -125db and the 3H as -138dB
The second is similar technology from Panasonic's model AV-7722A analyzer. It shows the 2H as -132dB and 3H as -135dB.
The affect of the notch is most likely cause for the difference... especially for the closest harmonic to the notch frequency (the 2H).
The ShibaSoku would be the more accurate one with less attentuation of the 2H by about 7dB.
Thx-RNMarsh
Old 16th August 2013, 05:47 AM   #20
richard-
Your making an assumption that the Shibasoku 725 isn't generating some second harmonic.
You may be able to verify the filter by introducing a second signal at levels around -100 dB to -120 dB near the second harmonic and see if they appear in the monitor output. You should be able to verify the noth filter response at H2. In the distortion analysis they are ignored until they phase modulate the harmonic and then you get weird results. (Beats) Its really hard to know who is generating which harmonic when both devices are around the same level. Since both the analyzer and the generator use a similar amplifier circuit they would have similar distortion signatures I suspect. The three stage notch in the Shibasoku means that the autotune will be less of an issue. I suspect it only works on the third stage.
Demian Martin
Audio Precision AP Analyser seriesHide this!Advertise here!
What are these resistors good for? AP precision axial metal film Rodeodave Parts 1 27th August 2010 09:24 PM
Visual Analyser, LX.1690 Analyser kit and other MAGICS!!! fotios Software Tools 8 18th March 2008 02:48 AM
Visual Analyser & Nuova Elletronica LX.1690 KIT Oscilloscope + Spectrum Analyser fotios Solid State 25 9th March 2008 08:35 PM
Audio analyser Mattwong Parts 8 19th December 2003 10:24 PM
Copyright ©1999-2017 diyAudio
