Inductance meter
I need a low cost( $40/$70) inductance meter mostly to built Xover. I try to avoid all in one meter since I get a good capacitance meter for last 20years.
LCR or only inductance will do. There is a lot on Ebay !
May be there is one not to bad :))
PS: if one just over my target price is a bargain/for price please let me know.
This one is not a real (stand alone) inductance meter, it is just an add-on for a multimeter that you can build for less than 10$, but it does actually work and is not a toy: it has better vector discrimination than many commercial units.
It can be helpful while looking for a complete instrument.
  • tiny_coil_panionV2-1.pdf
I use my sound card to measure inductance.
There are quite a few free software's out there that can do this with a simple interface resulting in a fairly good amount of accuracy.
Here is a discussion where I had put these to a test,
http://www.diyaudio.com/forums/software-tools/212908-exploring-visual-analyser-va-3.html#post3383659
and here as well,
http://www.diyaudio.com/forums/soft...peaker-impedance-tool-simpes.html#post3393589
Besides the above programs mentioned in those threads REW v5 beta 17 also does a super great job at impedance measurements as well.
FWIW
jer :)
Disabled Account
Joined 2012
L needs to be measured at the freq being used. Most L meters only give one test freq and it might not give you the same value at the in-use freq of operation. But if you use it for low freq xover and not above a few KHz, it will be close enough.
Thx-RNmarsh
