Equipment & Tools From test equipment to hand tools
B&K 650 tube tester
B&K 650 tube tester
Old 18th April 2013, 07:17 AM   #1
Rowdy1 is offline Rowdy1
Default B&K 650 tube tester
Hey folks: I am restoring a 650 tube tester and am having some issues. Namely that the schematic, and parts list, and the tester itself, don't all match up so as to enable me to restore the tester accurately.
R10 Not my biggest problem but. In the tester unit itself I found it to be degraded and almost double the value called out on the schematic and the color code on the resistor. Then while checking I find that a service update calls for testers previous to the 6000 SN to have the value changed from 100K 10% to 120K 5%, OK, and the parts list calls it out as 120K 5%. But in the tester unit itself (SN 202934) it has a 180K 5% resistor that had drifted to 223K. I evaluated the circuitry and opted to replace it with a 180K that tested at 179,023 ohms, well within 1% value. That is the goal I am attempting. I would like to bring every component within 1% and then a 1% accuracy in calibration should yield a tester that could discern mutual conductance close to 1% for matching tubes for stereo applications and finals in ham radio gear.
The second problem I have ran into is a little more perplexing in that while reading the service bulletin on R10 it states that R11 should also be changed from 22K to 27K. Now the real problem. The parts list calls out R11 at 27K but I can not find any R11 on the schematic. I also can not find any 22K or 27K resistor on the schematic or in the tube tester unit itself - ? ? I have a feeling that this will not be the last problem I run into on this restoration since I am only about half way through it. So I decided I should go in search of an expert on the subject. So here I am, looking
Any help would be greatly appreciated.
Rowdy
Old 18th April 2013, 12:25 PM   #2
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
B&K 650 tube tester B&K 650 tube tester
Changes thru production-years...
I would not bother doing all that 1% stuff, it will never be an 1% instrument anyway.
Hardly think my Amplitrex is 1%...
Arne K
Don't believe everything you think...
Old 18th April 2013, 06:13 PM   #3
v4lve lover is offline v4lve lover  Netherlands
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
B&K 650 tube tester
1% That's delusional.
B&K 650 tube testerHide this!Advertise here!
B&K 500 Tube Tester Calibration Captn Dave Equipment & Tools 4 4th May 2011 04:27 AM
B&K Tube Tester denny9167 Equipment & Tools 2 31st January 2011 08:08 PM
B&K 606 Tube Tester pjanda1 Swap Meet 5 30th March 2010 05:21 PM
B&K 747 tube tester tigro Equipment & Tools 2 24th November 2009 01:04 PM
B&K 650 tube tester not working, need help War Bird Radio Equipment & Tools 1 11th April 2004 11:56 PM
Copyright ©1999-2017 diyAudio
