Equipment & Tools From test equipment to hand tools
ShibaSoku Automatic Distortion Analyzer
Old 14th April 2014, 04:42 PM   #181
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
[QUOTE=1audio;3891311
Richards unit does have a noise problem, that my much older unit does not have. I think it relates to the post filter gain circuitry since its not real obvious in the analog outputs but I'm not sure yet.
[/QUOTE]
Thanks Demian. I bought some lower noise opamps for the filters/post filters and found the pcb that has the filters.... followed the wire from the front panel output port back to a pcb.
Its a great instrument... super accurate at measuring low harmonic levels.
-Richard
Old 1st June 2014, 11:53 PM   #182
alemi is offline alemi  Italy
Hi, I'm Alemi from Milan, Italy ... I wanted to know if the ShibaSoku AD725C of PChi member is still available for sale, thank you!
Old 7th June 2014, 05:40 AM   #183
RNMarsh's Avatar
Demian.
Have you made any progress on lowering the noise etc of the 725D ??
THx-Richard
Old 8th June 2014, 06:17 AM   #184
1audio is offline 1audio  United States
Ricard:
The basic noise of the 725D is about the same as the 725 and quite low. The analyzer circuit is working well and swapping a few opamps here and there helped. Getting the 20 KHz filter working better is very important. Its between the input amp and the first notch filter, it responded to opamp upgrades as well.
The monitor output noise is very much in line with what it should be. The metering circuit however has a problem and I have not figured out yet where the key circuit is. Its post filters and post distortion analysis, probably in the meter amp itself. That it doesn't change when the meter response is switched suggests its in that circuit. The older unit does not have the response control circuit so I'm flying blind.
I think it would also benefit from a DC cal of the input amps but I need an extender board to do it.
Demian Martin
Product Design Services
Old 9th June 2014, 03:17 AM   #185
RNMarsh's Avatar
I think it is on this pcb ---->
The first pcb on the left of the near center pcb gap. from front top view..... Or, follow the wire from the monitor output port to that pcb.
There is a group of pcb on the left and a gap and a larger group of pcb on the right. The first pcb of that larger, right, group of pcb.
-RM
Old 12th June 2014, 02:08 PM   #186
RNMarsh's Avatar
Default Analyzers for sale -
There are a couple of nice analyzers - for a very reasonable price - for sale on ebay at this time:
A gen/analyzer combo from shibasoku - model AM57A. .003% Full Scale and 0-120dB range. About $1500.
Also, a Panasonic VP7723A about the same price; .0005%/ 0-130db range.
-RNMarsh
Old 12th June 2014, 02:31 PM   #187
davada is offline davada  Canada
-RNMarsh
All very tempting. Is that THD or THD+N. I probably need something that goes lower for what I'm doing. Have you been able to extend the range using DM or notch?
David.
Old 13th June 2014, 05:28 AM   #188
RNMarsh's Avatar
they each measure both. But its THD spec number.
I have not tried a notch with the Panasonic --- own one.... dont own the other. With the Panasonic - it is a copy of the ShibaSoku concept and will show on loop-thru test better than spec's minimum. A notch will drop that to nothing, I guess.
-RM
Old 24th June 2014, 09:46 AM   #189
levelfive is offline levelfive  Russian Federation
Hi, Alemi
There is the great VP-7722A for sale on ebay at this time
www.Levelfive-Audio.com
Old 24th June 2014, 04:17 PM   #190
RNMarsh's Avatar
Originally Posted by levelfive View Post
Hi, Alemi
That is their best model. the one I use a lot. Highly recommended.
0-130dB distortion range. With internal source: .0001% max.
THx-RNmarsh
ShibaSoku Automatic Distortion AnalyzerHide this!Advertise here!
Meguro MAK-6571B Automatic Distortion Meter srh Equipment & Tools 8 19th January 2014 11:01 PM
Distortion Analyzer - Again Zero Cool Equipment & Tools 4 29th June 2013 11:14 PM
ADC SS-525X Automatic Spectrum Analyzer 503Timber Swap Meet 4 13th July 2011 10:05 PM
Shibasoku Distortion Meter, UK only dhaen Swap Meet 9 21st January 2011 03:53 PM
Recommendation on Distortion Analyzer Mark245 Solid State 2 19th December 2009 10:06 AM
Copyright ©1999-2017 diyAudio
