Equipment & Tools From test equipment to hand tools
EMU0204 mods for FFT measurements
Old 8th March 2013, 12:19 AM   #41
davada is offline davada  Canada
Originally Posted by dirkwright View Post
I'm certainly willing to buy what ever board you make, as long as it has the interfaces I need. I've gotten a lot better at soldering SMD's now... they take forever though.
Can you provide a list of these required interfaces?
David.
Old 8th March 2013, 01:58 PM   #42
dirkwright is offline dirkwright  United States
dirkwright's Avatar
l'd be happy with I2S output because that makes it easy to connect up a USB interface. I don't know enough to know what to suggest beyond that. How would you connect an ADC to a laptop? What's the best way? I have a USB 3.0 card, and USB 2.0 native on this laptop. I have almost zero experience with these kinds of converters. I have a MiniDSP USB interface, for example. I've used the Twisted Pear USB interface as well.
Old 8th March 2013, 05:18 PM   #43
Well I would just include a USB connection.
David.
Old 8th March 2013, 05:46 PM   #44
dirkwright's Avatar
Oh cool. So, which ADC are you wanting to use? Did you want a separate thread for this? The PCM4222 looks great, but I'm not married to it...
http://www.ti.com/lit/ds/symlink/pcm4222.pdf
OPA1632 inputs looks good also.
I can help with a group buy or what ever.
Old 8th March 2013, 06:18 PM   #45
AK5294A is what I' looking at.
I have a lot of research to do and I have to learn the Atmel procrssor.
This will take a while.
David.
Old 8th March 2013, 06:43 PM   #46
dirkwright's Avatar
Is that for the "system controller" shown in the AK5294A data sheet?
Old 8th March 2013, 06:45 PM   #47
glt is offline glt  United States
...and I have to learn the Atmel procrssor.
Use Arduino
www.hifiduino.wordpress.com
Old 8th March 2013, 08:23 PM   #48
Telstar is offline Telstar  Italy
Just be sure it has good drivers for all OS (or class 2+ windows drivers). And support at least 192khz.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 8th March 2013, 11:30 PM   #49
If you go back a few posts and look at what Demian linked to.
Use Arduino sure but the SDR-Widget doesn't use Arduino it uses the Atmel.
The project is open source and drivers are available for three OS and several OS versions.
I don't have time to create from scratch. It's easier to take code that's already developed and modify it for my purposes.
I don't mind learning new things but one at a time. Otherwise it gets too confusing.
Why is Arduino better? Why not Microchip?
David.
Old 8th March 2013, 11:35 PM   #50
I can't promise there won't be headaches involved. But test applications can be tried before
committing to hardware. Hardware emulators.
David.
EMU0204 mods for FFT measurementsHide this!Advertise here!
ICEPower 125ASX2 Measurements and Mods stokessd Class D 9 11th June 2013 10:26 PM
FFT, now even faster benb Everything Else 9 19th January 2012 05:21 AM
D/A preamp FFT measurements for review plz zigzagflux Tubes / Valves 30 10th March 2011 03:21 PM
what is an FFT graph? keantoken Everything Else 23 10th September 2006 12:13 AM
Distortion measurements using FFT software on PC/Mac peranders Everything Else 1 22nd April 2003 11:21 AM
Copyright ©1999-2017 diyAudio
