Equipment & Tools From test equipment to hand tools
QuantAsylum QA400 and QA401
Old 27th June 2018, 01:41 AM   #2501
gazzagazza is offline gazzagazza  New Zealand
For my QA400 I'm now also experimenting with Windows 8.1 installed on an external hard drive and booted on a USB 3.0 port. It seems to work quite well and isn't as slow as expected. I have it on an ex laptop 2.5" drive and will move it to an ssd next week.
For those interested you can buy an install key on eBay at present for just a few dollars... They say they are from decommissioned machines. Download the isos from Microsoft and you're up and running.
Old 27th June 2018, 06:54 AM   #2502
chris719 is online now chris719  United States
Originally Posted by 1audio View Post
Virtualization won't work. The QA401 needs direct connection to the hardware. In virtualization there is an intermediate software virtualizer that simulates the hardware and passes it through. This doesn't work for hardware like digitizers and audio cards that need direct access.
It can work but it's still a mixed bag. I was able to stream 1080p HDTV over a USB CableCard tuner via Windows Media Center in VMWare but had some lip sync issues.
The QA40x is more likely to work precisely because it's not a USB Audio Class device. I find most things that are using bulk or interrupt transfers work well in VMWare because they are common use cases (Mass Storage, HID). Isochronous is always the flakiest.
Old 27th June 2018, 06:58 AM   #2503
For those having problems with USB dropouts. Download LatencyMon (free) and run that plus the In-Depth Latency Checker and run the Tight Loop Latency Tests. If you can't stay in the green for these you are going to have problems with timely USB I/O. It should help you pinpoint the driver or service causing the issue, but sometimes it's not easy.
Old 28th June 2018, 12:01 AM   #2504
1audio is offline 1audio  United States
Originally Posted by MarkS View Post
What software do you use for multiple boot control?
For Windows only I use EasyBCD - NeoSmart Technologies which configured the Windows bootloader which does the work. You don't need it but life is easier with it. Systems with Linux I use Grub.
Demian Martin
Product Design Services
Old 28th June 2018, 12:45 AM   #2505
MarkS is offline MarkS  United Kingdom
Thanks for that, most useful...
Old 7th July 2018, 09:37 PM   #2506
ss2222a is offline ss2222a  United States
Hopefully this is the right place in this thread as this is my first DIY Audio post...
I have version 1.615 for my QA401. I've tried to create my own weighting table for ITU-R 468. It tells me that it's not loaded. The included RIAA weighting works fine, even if I modify it. The last time I tried, I got an error that has been logged and I can attach if needed. It seems straight forward. Am I doing something wrong or have I discovered a bug?
QuantAsylum QA400 and QA401Hide this!Advertise here!
QuantAsylum 401 & 405 B&W_arthur Equipment & Tools 5 22nd March 2016 04:27 PM
QA190 and QA400 Gains sgtnoah Equipment & Tools 4 17th July 2015 03:46 AM
Question on QA400 Alan0354 Equipment & Tools 7 10th July 2015 06:34 PM
FS QuantAsylum QA400 audio analyser jan.didden Swap Meet 3 29th September 2014 05:10 PM
New Quantasylum QA190 Differential Input Probe stellavox Equipment & Tools 3 20th March 2014 06:06 PM
