Equipment & Tools From test equipment to hand tools
QuantAsylum QA400 and QA401
Old 9th April 2013, 08:01 PM   #101
1audio is offline 1audio  United States
Default Revised interface schematic
Attached are the revised schematics including the probe cable drawings.
I will probably do a gen 2 of this now that I have it all working and look to see if I can shrink it enough to fit into the QA400 box. That version will be all surface mount etc. I won't get to that for some time.
This has the revised gains (6V in and 6V out) to better utilize the available dynamic range of the parts.
I hope the cable drawing explain better what the concept is.
If there is interest I'll fix the existing layout and post it (with the larger holes for the connectors).
If we are lucky QA will do a second gen of the box with this built in.
Demian Martin
Product Design Services
Old 10th April 2013, 05:54 AM   #102
mkc is offline mkc  Denmark
Hi demian,
Thank you for your effort. Your comment on QA perhaps making a second gen. box with this built in sounds really nice. However, I can't help thinking it would have been great if QA had considered making a box with a better ADC, like the one which is considered here in the capture widget. Perhaps the target audience is to small, considering the performance of the QA400. I would not mind paying more for that.
Mogens
Old 10th April 2013, 06:13 AM   #103
I would expect QA to be focusing on their primary customers, large manufacturing lines in China, who buy 100's at a time. We are really lucky that it can be re-purposed. The same box has many non audio test usages.
If he does make a premium box expect it to be considerably more money for a small gain. .0005% THD will show problems with any real amp, preamp, digital converter etc.
While I don't expect it to replace my bench system immediately, it already travels with me.
Demian Martin
Old 10th April 2013, 12:34 PM   #104
Telstar is offline Telstar  Italy
This would be great
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 10th April 2013, 01:27 PM   #105
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Whoahhh! New computer for the lab, I'm in bizz. No more link drops.
Data export works nice, now can have pub quality output.
Great!
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 10th April 2013, 01:30 PM   #106
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
That looks good.
Old 10th April 2013, 07:02 PM   #107
RNMarsh is online now RNMarsh  United States
RNMarsh's Avatar
Great!
jan
I'll have to get me one of those, then.
What computer did you get and where?
Thx-Richard
Old 13th April 2013, 04:05 PM   #108
Hi Richard,
Did you ever get your QA400 working again?
I have just tried mine out on my Lenovo T410 win7/64 bit. Didn't work. Lots of drops. Then I plugged it in my office computer again, which runs ver 1.0 of the software and previously worked, but now it doesn't work either.
I have only measured a AC coupled B1 like buffer with it and it worked fine and it has been standing unplugged since.
I would be very surprised if I have damaged the USB port in the QA400 with this handling. Then they will most certainly have a lot of trouble in the field.
One thing though. I'm running W7/64 bit and I can't rule out a Microsoft update could be the cause, but I do find it a bit unlikely.
Mogens
Old 13th April 2013, 05:29 PM   #109
jan.didden's Avatar
I got a new PC for my lab (also for other equipment) and the QA400 works on one specific USB port, flawless, not a single drop.
If I plug it into another USB port, it works erratic with lots of drops.
Go figure.
jan
Old 13th April 2013, 05:36 PM   #110
RNMarsh's Avatar
MKC -
No. I really lost patience with anything related to Microsoft many years ago. Its PnP for me or I'm outta here. BUT... when i get bored with life, I might take another shot at it. my experience is like yours and others. It works, it doesnt work etc. too buggy for me. I'd even buy a new computer if someone would tell me the darn ADC would work perfectly all the time. For me, its just torture anyway you define it.
I have 2 QA400 and neither works very well. So its drivers/Win interface issues with my computer(s). Just dont want to spend my time that way --- Unless, I couldnt measure thd and would be under force to make it work. Fortunately, i can measure lower than the ADC systems doing it the Old ways.
I'll probably twist my own arm and buy a commercial FFT (SRS S1), sooner or later.
Put it on the charge card.
Thanks for the good info...
-Richard
QuantAsylum QA400 and QA401Hide this!Advertise here!
QuantAsylum 401 & 405 B&W_arthur Equipment & Tools 5 22nd March 2016 05:27 PM
QA190 and QA400 Gains sgtnoah Equipment & Tools 4 17th July 2015 04:46 AM
Question on QA400 Alan0354 Equipment & Tools 7 10th July 2015 07:34 PM
FS QuantAsylum QA400 audio analyser jan.didden Swap Meet 3 29th September 2014 06:10 PM
New Quantasylum QA190 Differential Input Probe stellavox Equipment & Tools 3 20th March 2014 07:06 PM
Copyright ©1999-2017 diyAudio
