Equipment & Tools From test equipment to hand tools
Later Exar 2206 different than earlier?
Old 6th January 2013, 04:36 AM   #1
Conrad Hoffman is offline Conrad Hoffman  United States
Default Later Exar 2206 different than earlier?
I needed a quick and dirty oscillator and did the single supply data sheet circuit using an Exar 2206. I prototyped it with some fairly old parts I had and it worked great. New parts just ordered are unstable in the same circuit. The only thing I found on the 'net was a similar problem when running higher (but within datasheet limits) power supply voltages. Has anybody seen or heard about anything like this?
I may be barking up the wrong tree, but at least I'm barking!
Old 6th January 2013, 10:44 PM   #2
kevinkr's Avatar
Moved to equipment and tools as I suspect you would be a little more likely to get an answer here..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Later Exar 2206 different than earlier?Hide this!Advertise here!
Any Exp. w TH using JBL 2206 or 2226? HK26147 Subwoofers 12 2nd July 2014 04:45 PM
Is the EXAR XR-084 quad bi-fet opamp any good? cyclecamper Solid State 26 23rd March 2012 02:17 AM
Speaker DIY in Wisconsin This is a repost for any who missed my earlier message se loninappleton Multi-Way 2 23rd January 2010 06:35 AM
JBL 2206 possible problem: jpnoll Subwoofers 4 26th December 2009 05:12 AM
JBL 2206 crosswover b3keys Multi-Way 1 29th April 2009 07:08 AM
Copyright ©1999-2017 diyAudio
