Equipment & Tools From test equipment to hand tools
DIY Circle Jig
DIY Circle Jig
Old 2nd January 2013, 02:05 AM   #1
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
DIY Circle Jig
Default DIY Circle Jig
I made one before but can't find it so made a new one yesterday. It is pretty crude, but the original one worked well enough. Thought I'd share as it is pretty easy to make.
I Still need to test to work out if my measurements are correct, but it is easy enough to drill more dowel holes to get whatever size hole you need
Basically I just used a piece of Masonite, removed the plate off the router (and used as a template to mark the holes for the mounting screws (suitably countersunk).
I then attached it to the router and plunged very carefully with a countersink bit to get a pinhole at the dead centre of the router bit.
I then got my compass and (initally with pencil) scribed a 40mm diameter circle around that point. I also scribed lines through the centre of the circle.
I reattached the piece of masonite and plunged the bit I will use for cutting through the board (note I may need to plunge a bigger hole to allow for dust extraction), I can't remember if that was an issue last time).
Holes are then drilled in the board measured from the outside of the hole made by the router along one of the scribed lines. The distance between the two points being the radius of the hole to cut. Later if hole is enlarged, the distance between the 40mm scribed circle and the edge of the bit can be determined and offset added to get the correct distance.
I had a ~1/4" dowel handy which fits very snuggly in a 15/64th" hole.
I may get a chance to try it out this evening, and then if ok will route the cutout for the speaker I'm currently building.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 5th January 2013, 05:49 AM   #2
just another
wintermute's Avatar
DIY Circle Jig
and just to show that it does actually work here are a few pictures
The first one is after doing the rebate, + an initial cut to the same depth as the rebate for the inner hole. Others showing speaker fit and the final baffle sitting on the box (not yet actually glued together).
Tony.
Some of my photos
Old 18th July 2013, 10:42 PM   #3
fringy75 is offline fringy75  New Zealand
fringy75's Avatar
Hi Tony. Thanks for posting this, it is going to save me a heap of money purchasing a specialist jig
One of the advantages of being disorderly is that one is constantly making exciting discoveries.
Old 19th July 2013, 01:40 AM   #4
just another
wintermute's Avatar
DIY Circle Jig
No problem fringy I figure if I can make it myself why not!! I originally thought about getting a jasper jig, but by the time you added shipping it was going to be rather expensive!
Tony.
Some of my photos
Old 2nd August 2013, 01:20 PM   #5
viki_v2 is offline viki_v2  India
viki_v2's Avatar
Tony.
Which driver is it, one You have shown in image
Old 2nd August 2013, 01:23 PM   #6
just another
wintermute's Avatar
DIY Circle Jig
It is an SB acoustics SB12MNRX25-4 more info here --> http://www.diyaudio.com/forums/full-...ld-thread.html
Tony.
Some of my photos
Old 10th August 2013, 01:13 PM   #7
Elabreak is offline Elabreak  Bangladesh
Banned
Nice photo..
DIY Circle JigHide this!Advertise here!
small hole circle router jig, with pictures tinitus Equipment & Tools 20 14th January 2013 09:49 AM
WTB : Jasper Circle Jig Cacophonix Swap Meet 2 23rd March 2005 04:35 AM
Looking for Japser Circle Jig chris ma Swap Meet 14 6th June 2004 01:02 AM
Home made circle cutting jig nuppe Everything Else 3 5th June 2004 12:39 PM
FS: Plunge router and Jasper circle jig bsteeves Swap Meet 7 18th June 2003 05:29 PM
Copyright ©1999-2017 diyAudio
