Equipment & Tools From test equipment to hand tools
Using 3D printing in DIY projects
Old 1st January 2013, 06:58 PM   #1
drfrink25 is offline drfrink25
Default Using 3D printing in DIY projects
Since 3D printers are getting pretty affordable, I was wondering if anyone has considered how to leverage their capability in your projects? While I don't have the CAD skills, tools or knowledge to do this myself, here are some broad ideas I was thinking of:
Complex, multi-part waveform guides - These would have been impossible to create yourself prior to 3D printing. Given the size of 3D printers is limited, larger enclosures would need to be printed in multiple parts.
Complex diffussion faceplates/speaker surrounds
Complex internal baffles
Complex porting methods
Anyone else have many ideas? All I can find on teh googles is iphone horns and other small stuff.
Old 1st January 2013, 07:34 PM   #2
derwhalfisch is offline derwhalfisch  New Zealand
I'm seriously considering building a printer to make throats for synergy horns.
Old 1st January 2013, 07:41 PM   #3
wesayso is offline wesayso  Netherlands
wesayso's Avatar
I use it for Car Audio, (pods for Vifa XT25-SC tweeter)
I use one of the online printing services to make them. Can't say it's cheap though.
But I like the fact that I can make most of what I can dream up.
Old 1st January 2013, 09:33 PM   #4
Audiodidakt is offline Audiodidakt  Norway
What would the cost be like for i.e. an ordinary 18 cm waveguide?
Old 1st January 2013, 09:45 PM   #5
harvylogan is offline harvylogan  United States
harvylogan's Avatar
I have used stereo lithography quite a bit in the past for tweeter mounting plates, waveguides of relatively small size that I can screw onto a specific tweeter, odd shaped driver trim rings to French the transition to the baffle surface to avoid making a routing jig and also terminal plates that actually have the right number of terminals I need and fit the material I am using. I have access to some machines and run them for material cost only since I do all the modeling myself. I have sent some of my design models out for bid on more than one occasion and the bids I got back were very cost prohibitive for me. I know the material costs because I do SLA and the machine cost to do simple parts say up to 8” X 10” is anywhere from 10-50K so for the most part most SLA companies charge exorbitantly high prices because they deal in R&D prototyping for large companies that have a budget that can be re-cooped in production runs once the product is finalized. There may be companies out there that do small one-off runs efficiently but I have not found any.
Old 1st January 2013, 09:51 PM   #6
harvylogan's Avatar
I have made them (8") for $6.00 in material and the run time for each part was 12hrs. The same part was quoted to me twice from 2 different companies to do a 6 piece run @ $600, and $1150 for the run.
Old 2nd January 2013, 01:32 PM   #7
Here is something fairly large and complex made out of pieces from a makerbot ($2200)
Cosmo Wenman's Mind-Blowing Sculpture Made On A MakerBot
Old 15th February 2014, 11:34 AM   #8
Tony X is offline Tony X  France
Tony X's Avatar
Default 3D Horn printing
It should be possible to print a horn like. The maths can't be that complicated and it would be fun. I have no access nor experience with this technology but it is fascinating to ponder the possibilities. What material to choose would already be way outside my competence.
Anybody out there who has already given it a go or wants to try?
Parfois, martyr lassé des pôles et des zones
Rimbaud - Le bateau ivre
Old 27th June 2014, 06:19 PM   #9
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I saw an idea posted on the Hewlett Packard/Agilent Yahoo Group -- use 3d printing to lay down etch resistant PCB traces!
By the same token one could take an aluminum panel and via "negative" printing mask all but the lettering you wanted, then etch the lettering or patterns.
Old 23rd July 2014, 05:37 PM   #10
Killingbeans is offline Killingbeans  Denmark
I'm thinking about building a sort of poor man's Elipson 4260.
Elipson - 4260
The midrange+tweeter part would be a good candidate for 3D printing.
A perfect sphere on the outside and a structure with a minimum of standing waves on the inside, divided by a gab filled with sand. That's my idea so far.
Also, it would be super sexy to make it out of this stuff:
Carbon Fiber Reinforced PLA ? PROTO-PASTA
Using 3D printing in DIY projectsHide this!Advertise here!
3D Pic... you need Anaglyph 3D Glasses to view moe29 The Lounge 13 18th June 2013 12:56 PM
what clock diy projects are currently available? jarthel Digital Source 4 6th September 2006 02:14 AM
