Equipment & Tools From test equipment to hand tools
Trio CS-1554 Blew the PIO Intensity Capacitor, why?
Old 16th December 2012, 10:00 AM   #1
freax is offline freax
freax's Avatar
Default Trio CS-1554 Blew the PIO Intensity Capacitor, why?
I was doing some measurements last night of my TDA1543 dac's I/V stage and I was using a Trio CS-1554 Dual Trace Oscilloscope when I heard a loud fizz and it was coming from the Trio.
I was using it for approximatley 15 minutes with the input voltage range set correctly.
Sure enough this afternoon I took off the covers to the Trio and noticed that the oil that had covered the inside of the case was coming from a 1500 WV PIO 0.5uF capacitor up at the front of the unit.
This unit is a fully transistorised one and works perfectly fine aside from being the age that it is and this PIO capacitor blowing.
The PIO cap in question is attached to the Intensity trimpot, The second one from the bottom.
What caused this? was it caused by old age or some other faulty component like the main filtering capacitor losing capacitance?, ie that one going to the trimpot from the pio cap?
I was hoping to get this cleared up as I have a sister Trio back at home and it will have an identical pair of capacitors in it that I can use for spares
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 10th July 2013, 08:52 AM   #2
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
rectifiers ... ?
Old 10th July 2013, 09:08 AM   #3
Enzo is offline Enzo  United States
Or simple random component failure.
Old 25th July 2013, 03:54 PM   #4
seppoa is offline seppoa  Sweden
According to my experience, PIO caps are not very trustwhorthy, and fails by no appearant cause, maybe of old age sometimes. In my years as a TV repair technician in the ages of tube equipment I have changed thousands of PIO caps due to leakage or shorts. And they can emit lots of smoke, to scare the owners.
Trio CS-1554 Blew the PIO Intensity Capacitor, why?Hide this!Advertise here!
Kenwood trio cs 1040 itamar Equipment & Tools 0 6th November 2011 04:00 PM
Looking for oscciloscope Trio cs-1560a remis370 Everything Else 1 31st October 2011 01:36 AM
TRIO 15Hz Oscilloscope CS-1560A engels Tubes / Valves 2 18th February 2008 09:39 PM
New PIO Capacitor! serengetiplains Parts 90 11th December 2007 06:12 PM
