Equipment & Tools From test equipment to hand tools
Finally made a test load
Old 18th November 2012, 04:09 AM   #1
Conrad Hoffman is offline Conrad Hoffman  United States
Default Finally made a test load
For years I've cobbled together whatever test load I needed using clip leads and luck. I finally made up a proper load by mounting 10 40 ohm 50 watt resistors on a slab of heat sink. The metal was scrap I had around the shop. The banana jacks are arranged at 3/4" square so they can easily be shorted to make a single 4 or 16 ohm load out of the dual 8s. I don't normally test for long, but if needed it's easy enough to blow on it with a fan.
I may be barking up the wrong tree, but at least I'm barking!
Old 18th November 2012, 04:16 AM   #2
freax is offline freax
freax's Avatar
hehe, nice work!
Old 19th November 2012, 08:22 PM   #3
cyclecamper is offline cyclecamper  United States
Nice, I like it. Any inductance in each resistor doesn't add up.
Add an aluminum base to one "end" so that becomes the bottom and it stands up vertically. If it gets warm it will generate its own convection. And the smaller footprint will take up less space on your bench.
Old 20th November 2012, 12:41 PM   #4
Actually the center of gravity is such that it stands on its side with no problem. Thanks though, as I hadn't really thought of using it that way!
Old 21st November 2012, 08:53 AM   #5
That would probably even work on some of my huge amps with a small fan. Nice use for some unmatched pieces of heat-sink I might have laying around.
Finally made a test loadHide this!Advertise here!
Finally made a LM1875 amp BrianGT Chip Amps 176 29th January 2016 06:35 PM
I finally made a good working transistor amplifier realflow100 Solid State 18 18th October 2012 02:27 PM
FINALLY, a subwoofer amp made in the UK Village Plank Subwoofers 4 19th April 2010 08:03 PM
Finally made it in the PassDIY pages! Blues Pass Labs 23 28th July 2004 04:05 AM
Finally made a new webpage! Duo Everything Else 24 17th January 2003 12:29 PM
Copyright ©1999-2017 diyAudio
