Equipment & Tools From test equipment to hand tools
I want to test regulator output impedance!! How to setting AP2722?
Old 25th October 2012, 05:12 PM   #1
cacaca is offline cacaca
Default I want to test regulator output impedance!! How to setting AP2722?
I have to use the super regulator circuit!
I want use the AP2722 to test the performance of super regulator.
But I don't know how to setting AP2722?
I want to test output impedance and LR and noise!!
thank you!!
Old 28th October 2012, 04:16 PM   #2
Samuel Groner is offline Samuel Groner  Switzerland
Have you tried the manual and their applications support? This is a complicated piece of equipment, and it would cost me much time to guide you through all the details.
Samuel
Old 29th October 2012, 07:51 AM   #3
Samuel
I know how to seting the LR and noise test.
But i don't know how to setting of impedance test.
Analog analyzer should be choice which?
Bandpass or band reject , THN or other.
Whether should be to select FFT??
Old 29th October 2012, 10:55 AM   #4
I think your problem is more related to the basic impedance measurement rather than the operation of the SYS-2722. Basically you inject a current and measure resulting voltage drop, which by Ohm's law can be referred back to impedance. How you measure the voltage depends on many variables--usually it is a small voltage so you use a narrow band measurement.
See also:
http://icom.hsr.ch/fileadmin/user_up...C_Meter_EN.pdf
http://cp.literature.agilent.com/lit.../5950-3000.pdf
Samuel
I want to test regulator output impedance!! How to setting AP2722?Hide this!Advertise here!
SET output impedance vs speaker impedance Arno Pf Tubes / Valves 3 20th April 2012 08:37 PM
6h23N test setting? phrarod Tubes / Valves 6 30th March 2012 08:03 PM
Regulator output impedance jesper Solid State 34 23rd February 2011 11:08 PM
Amp impedance setting to drive ESL57s Richard (Wales) Planars & Exotics 17 19th February 2011 07:09 PM
How To Test For Input Impedance? kelticwizard Solid State 20 19th July 2006 02:01 AM
Copyright ©1999-2017 diyAudio
