Equipment & Tools From test equipment to hand tools
E-MU 0404 usb 2.0 and some "artifacts peaks" on left channel
Old 26th October 2012, 07:03 PM   #11
iko is offline iko  Canada
iko's Avatar
There's a thread or wiki on this site in which I tried to identify the on-board chips. There were quite a few dc-dc converters to provide various positive and negative rail voltages, all running at various kHz speeds.
Edit: found it. http://www.diyaudio.com/wiki/E-MU_0404_USB_mod_wiki
Old 26th October 2012, 11:50 PM   #12
sidiy is offline sidiy  Canada
sidiy's Avatar
Thanks Ikoflexer,
Starting from that thread I did some homework and found these links of interest:
Inside view
Loopback tests
I also opened my unit and I think I found the problem. They announced some rain in Montreal this week-end... so stay tuned. I will post pictures and a step-by-step "how to"... if my fix works.
There are no door prizes but if anyone cares to take a guess...
Make two for stereo
Old 27th October 2012, 06:38 PM   #13
iko's Avatar
Bad caps?
Old 27th October 2012, 09:03 PM   #14
qusp is offline qusp  Australia
qusp's Avatar
oh I dunno, the 12MHz crystal, plus what appears to be DGND and some DC->DC convertors in the second pic, folds over when closed and sits directly above the dac? in the pic with the boards folded out like a book it appears that section will sit directly above and VERY close
Old 27th October 2012, 09:40 PM   #15
qusp's Avatar
wrong, its the DIR it sits above. with that 12MHz XO there clocking a logoc, FPGA, and the boards folding over like that, its a recipe for noise. I would test to see if you can get it to work with it folded open and just track it down
Old 28th October 2012, 01:55 AM   #16
sidiy's Avatar
Well, it worked... I have a bunch of photos, starting with a general view of the troubled area. I ruled out the DAC and output circuits since (luckily) these did not meet the conditions.
Make two for stereo
Old 28th October 2012, 02:42 AM   #17
sidiy's Avatar
Next one shows a "textbook" example on how a differential pair should not be routed !
The ADC has a yellow dot where the AINL pins are. All is good up to the anti-glitch capacitor C101 which is not far, but after that the show is on...the traces go on different inner layers and cross each other and then come on top at R151 (from pin 4) and R167 (from pin 5).
The colors tell the rest of the story, a nice loop is formed (the green trace even changes layer, where dotted, near the top right sot23s). There is a DC-DC converter right above with an unshielded inductor, L6 and an FPGA that has to run data at USB rates (plenty of traces there parallel to our top trace).
On a brighter note the blue lines show the right channel pair routed on a inner layer and top layer. They're close togheter and far from dangers.
I guess waiting for a board revision is out of the question, since the 0404 is obsoleted
Make two for stereo
Old 28th October 2012, 03:21 AM   #18
sidiy's Avatar
The fix is obvious.
1. Lift R151 and R167
2. Cut the traces near the pads of R123 and R128 as shown, making sure not to go too deep or to chip some neighboring components.
3. Solder a pair of wires, twisted a couple of times, to rework the connection. On the right side I chose the pads of R108 and R110 which belong to the same original nodes while for the left side I used the leftmost pads of R151 and R167. I did not want to pass the wires over the ADC to C101, not optimal in my opinion. Make sure not to reverse the phase.
Note: Photos are now turned upside down, makes easier to read component designators... sorry, my bad.
Make two for stereo
Old 28th October 2012, 03:50 AM   #19
sidiy's Avatar
I reassembled my EMU without any other touch-ups or upgrades. Apart from the mod shown my unit is still in "stock" form. As external supply I use a breadboarded LT3080 supplied with a 9V switching walwart.
Before showing the results I will post for reference some older tests. The photos are lower rez and cropped differently than the new ones. On top of that I don't recall the sample rates used but by their looks they're higher than 88.2k.
But it doesn't matter anyway - as you'll see later.
The left channel looks pretty busy...
Make two for stereo
Old 28th October 2012, 04:03 AM   #20
sidiy's Avatar
And the results...
I saved the measurements only for 44.1k and 192k, but I checked all the rates and the results are pretty much identical - considering the corresponding measurement bandwiths for each case.
Make two for stereo
E-MU 0404 usb 2.0 and some "artifacts peaks" on left channelHide this!Advertise here!
E-MU 0404 USB Modification? lumanauw Digital Line Level 239 2nd March 2018 11:58 PM
E-mu 0404 problem tonyptony Digital Line Level 2 25th August 2012 01:00 AM
Opinions on pc/mobo "onboard spdif to Ian's FIFO kit" or "USB to WaveIO" to I2s? edbk PC Based 0 1st May 2012 02:40 PM
FS: E-mu 0404 USB external sound card Jack Hidley Swap Meet 2 14th March 2008 01:00 AM
