Equipment & Tools From test equipment to hand tools
Uni-T UT61E DMM
Uni-T UT61E DMM
Old 3rd October 2012, 08:51 PM   #1
PedroDaGr8 is offline PedroDaGr8  United States
PedroDaGr8's Avatar
Default Uni-T UT61E DMM
It's funny, I have had this meter for a while but didn't think to post it here until today. I know people on here (especially those new to electronics) are looking for a relatively inexpensive (<$100) quality DMM. I decided to share this meter because its a great quality meter that doesn't break the bank.
I was looking for a decent hobbyist meter and knew that I couldn't afford a Fluke and didn't have the space for a lot of the huge benchtop ones on ebay that go for cheaper. Anyways, while researching I came across this meter (Uni-T UT61E) on the EEVBlog forums. In general the reviews were that it was well built and seemed OK, in particular it seemed to do what it said. I decided to get it, mainly due to price. I had a coupon for DinoDirect that ended up making the meter only $41. At that price point alone, the fact that it was auto-ranging and TrueRMS made it a good deal feature wise. Since then , its become much more apparent of how good of a value this meter is. At the time of posting, this meter will cost you around $50-55 shipped (from China) and IMHO is by far the bang for the buck for a new meter.
First the specs/features:
  • Auto-Ranging (and unlike most meters in this price range is really fast at it too)
  • TrueRMS
  • Rapid update display (I think I read it updates twice a second) with bar graph.
  • 22,000 Count - not 6,000 count like my 116 and most other meters in this price range (if they aren't lower)
  • 0.1% DC voltage accuracy (across the whole range from mV to 100's of V)
  • 0.8%(45-1kHz) or 1.2%(1kHz-10kHz) AC Voltage accuracy
  • 0.5% Resistance accuracy
  • 3.0% Capacitance accuracy
  • 0.01% frequency accuracy (10Hz-220Mhz)
  • Continuity test is pretty much instantaneous.
  • Hold, Peak and Relative difference functions (great for measuring very low capacitance values. You can zero out the capacitance from the wires).
  • Opto-isolated RS232 Data Logging (or USB data logging with an RS232-USB adapter)
A quick aside:
Do NOT confuse this meter with ANY others in the Uni-T lineup. Uni-T is a VERY hit or miss company. When they do it well they do it REALLLY well, when they don't the device borders on complete crap.
Initial Impressions:
The thing is SOLID, when I say solid I mean better than the Fluke 116 I use in my chemistry lab. Though truthfully, that 116 is kind of disappointing both inside and out. Even with all of the screws removed the device does not flex at ALL when I torque it in my hands. The dial has a nice solid click when you switch between functions with a good ka-chunk into the off position. The stand is sturdy and doesn't flex, I have no problem changing functions on this meter with one hand. The digits on the screen are LARGE with great contrast and the beep for continuity testing is good and loud.
Internally, the meter is pretty good to quite good. The input protection is adequate enough to be safe (much better than most chinese made meters) but not to the level of a Fluke (the one area where the 116 shines). It uses CooperBusman Arc-rated solid fuses (not glass fuses which can transmit an arc flash), has two PTCs and resistors, etc. Soldering is pretty good in most places, there are a few places where the hand soldering could be better. Some older versions (before mine) had weird manufacturing "fixes" such as stacked SMD caps. Recent revisions to the board have taken care of most of these.
Specs and Testing:
One of the most important thing is does it actually do what it is designed to do? As you know there are a lot of meters that have high ratings but unless its a solar eclipse and you are in Antarctica standing on your head they will never meet it. For example, the DMM company Victor is well known for drastically overstating their accuracy. Victor DMMs a are sold under a variety of different makes but the model names are usually VCxx or VAxx. Anyways, I decided to put this meter through its paces using some 0.1% KOASpeer resistors and a variety of caps I had laying around (Panasonic, UCC and eSC). Link to test data I had multiples of each value (at least 10 for the resistors) so I measured all of them and took an average. The resistors consistently showed an error of around 0.25-0.3% low, meaning that this meter could theoretically be adjusted to a much tighter accuracy. The capacitors actually were actually really close to their rated values. For example, the 100nF Panasonic caps tested within 0.3% of their stated value, while at a much higher capacity the UCC 100V 2200uF (huge freaking caps) had an error of 1.0% from their rated value. The only ones that tested outside of the boundaries of the accuracy of the meter were the eSC caps. Truthfully, I think thats just because they are crap. In the future I'd like to get some 1% caps to really push this meter on the cap measurement.
Conclusion:
This meter is damn well worth the money. It's solidly built, does what it says it can do and is a damn good price. There are a few downsides, one is no backlight on the display. The second is the probes sometimes have a film on the tips that can mess with the measurements. Wiping with isopropanol (rubbing alcohol) supposedly takes care of this.
Old 4th October 2012, 09:54 PM   #2
PedroDaGr8's Avatar
Edited to make the posts more readable.
Old 13th June 2014, 03:05 PM   #3
Tolik is offline Tolik  Israel
Tolik's Avatar
Uni-T UT61E DMM
I own this DMM. Excellent product. I replaced the probes with fine tipped SMT probes purchased separately, and added backlight. The main chip of that DMM is stuffed with backlight control option, and the LCD has 2 slots for the LEDs. So by adding only several components I got sensor controlled backlight. The project is here http://www.diyaudio.com/forums/equip...light-mod.html
Those who can, do. Those who can't, teach. Those who can't teach, do research. H.L. Mencken
Uni-T UT61E DMMHide this!Advertise here!
UNI-T UT600 Capacitance meter? Mayday Equipment & Tools 4 26th January 2012 07:29 AM
Uni directional mic - help needed Wavebourn Instruments and Amps 0 6th January 2007 12:49 AM
Uni - electrical or electronic engineering? bob123 Everything Else 19 27th December 2005 08:26 PM
KEF UNI-Q Driver Data banksyw Multi-Way 2 8th June 2005 10:34 PM
Uni project help Piper Solid State 6 18th June 2004 12:10 PM
Copyright ©1999-2017 diyAudio
