Equipment & Tools From test equipment to hand tools
Instrumentation amplifiers
Old 30th September 2012, 08:20 PM   #1
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Default Instrumentation amplifiers
I was wondering if anyone had thought about using a high CMRR instrumentation amplifier like the AD8429:
AD8429 datasheet and product info | 1 nV/?Hz Low Noise Instrumentation Amplifier | Instrumentation Amplifiers | Analog Devices
as part of a THD test facility. What I mean is to feed an oscillator input to one input of the in amp, feed the output of a DUT to the other input of the in amp, and thus the output would be the distortion which then could be fed to a FFT analyser. Seems like a simple idea to me.
Old 30th September 2012, 08:31 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Yes it's simple, if you can adjust the two levels to be exactly the same (for a -100dB distortion resolution, for instance, you need to match levels to 1:100,000 which is about 0.0001dB) and also compensate for the additional phase delay for the signal going through the DUT
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 30th September 2012, 09:01 PM   #3
Conrad Hoffman is offline Conrad Hoffman  United States
As above, plus unless you build the rest of the THD analyzer with auto tuning and phase nulling, you'll probably degrade the FFT output as opposed to improving it!
I do like differential tests where you compare the input and output of the DUT, say a power amp, playing music into a load, and the instrumentation amp is perfect for that.
I may be barking up the wrong tree, but at least I'm barking!
Old 30th September 2012, 10:43 PM   #4
dirkwright's Avatar
Thanks. I had actually realized that I have to match levels, but didn't mention it. I was thinking of providing some kind of tuning indicator that shows when the signals are exactly equal. I had not done the math though, so a 0.0001dB match would probably be really hard to make unless the error was amplified by 100dB or so.
The issues of phase shift I had not considered and would be an obvious problem.
I like this idea though because it would cancel out the distortion components from the osciallator.
Old 30th September 2012, 10:46 PM   #5
dirkwright's Avatar
Yeah, it's all still a thought bubble in my head right now. I don't know about correcting for phase shifts, so I have some reading to do. Thanks for your reply.
Old 30th September 2012, 11:32 PM   #6
dirkwright's Avatar
I guess you'd need an oscillator with a really stable output as well, but that's probably true for all measurements.
Old 1st October 2012, 08:49 AM   #7
coluke is offline coluke  Italy
Yess - Analog Devices AN-245 : Instrumentation amplifiers solve unusual design problems, by Scott Wurcer and Walt Jung - page 10-15. It works very well, and if you're only interested in extending the dynamic range of a spectrum analyzer, then you can relax quite a bit limits on null depth - Bob Cordell's THD magnifier is based on the very same principle.
L.
Old 1st October 2012, 12:24 PM   #8
dirkwright's Avatar
L.
Thanks! It looks like I've reinvented the wheel, which is a good thing actually. I have some reading to do!
I've never looked at Bob Cordell's "THD magnifier", so thanks for the tip.
Old 1st October 2012, 02:17 PM   #9
Samuel Groner is offline Samuel Groner  Switzerland
0.0001 dB.
As you're feeding a FFT analyzer that good level matching is not necessary. 60 dB suppression should be enough. But keep in mind that the instrumentation amplifier has its own distortion contribution in such an application as it sees large common-mode swing.
Samuel
Old 2nd October 2012, 05:50 PM   #10
dirkwright's Avatar
I ordered Linear Audio number 0 today. I need the schematic for Bob's DM. I want to see if I can add some features to it.
Instrumentation amplifiersHide this!Advertise here!
Instrumentation Gainclone BWRX Chip Amps 70 16th May 2013 04:59 PM
Instrumentation Amp: Input Resistors? claas Analog Line Level 0 7th May 2011 02:25 PM
Instrumentation op-amps for audio ivanlukic Analog Line Level 10 28th November 2010 12:31 PM
M-Audio Delta-44 and instrumentation under Linux suzyj Digital Source 8 27th July 2007 03:43 PM
Why not "instrumentation amplifiers" jackinnj Solid State 11 29th June 2003 08:00 AM
