Equipment & Tools From test equipment to hand tools
Dremel Trio ... sufficient tool?
Old 29th September 2012, 12:35 AM   #21
tomchr is offline tomchr  Canada
tomchr's Avatar
You should be able to get Bosch products in Europe. It's a German brand and is quite popular there. I love my Bosch miter saw and cordless drill.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 29th September 2012, 12:52 AM   #22
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
~Tom
Metabo is better!
Regards zeoN_Rider
Old 29th September 2012, 09:15 PM   #23
overtheairbroadcast is offline overtheairbroadcast  Canada
Guys, remember Daniel/Imagio's first constraint -- the money. He wanted one that could be around 150 Euro, I think that is the hardest part.
Old 2nd October 2012, 06:54 PM   #24
imagios is offline imagios  Czech Republic
Ok the Makita should arrive tomorrow, it has some good references the only downside is and it a big one it can use only 6mm bits,... and most of them are 8mm, it has no rpm set up, so its I guess similar with to the Bosh Colt, I hope to be able to do the small boxes with it...
Old 2nd October 2012, 09:46 PM   #25
Patience and time. Congratulations! You have what some people call the King of Tools. Now go watch those Youtube videos on how to use it properly without burning your wood or making it look rough on a single pass.
More importantly, get something for your eyes, ears, and nose. Then afterwards, show us what you have made.
Old 3rd October 2012, 11:04 PM   #26
The tool did not arrived so far, but here is the thread to the construction discussions
Tang Band W5-704 and a TB ceramic tweeter
Old 7th October 2012, 11:03 PM   #27
ok I got the small Makita, and one bit,
first of all, really dont try to do the work at home, I gave it a try in the kitchen, and I never imagined so much dust from so small work...
Never the less I had a way to my father in law so I have done the most at his garden.
The tool performes well, the power is quite limited and the selection of 6mm bits is terrible, but I managed to do most of the work.
I just have one issue I dont know how to solve, I have to cut small cycles for the tweeter, for example a diameter of 5cm, 2 inches, how do I do that with the router, most the router has some equipment, but with the providet exuipment I cant make circles smaller than aprox 12cm...
Any solutions?
I will soon share some pictures
Old 7th October 2012, 11:40 PM   #28
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
Imagios,
Did your router come with a fixture ( a small round disk with a protuding tube in which a router bit fits, sticking out) to cut from a template? If so, the method for small holes is to make a precise template from a piece of MDF. With some craft, it is not that difficult to jigsaw and sandpaper a pretty perfectly round circle in MDF.
But from now on I will be discrete about it.
Old 8th October 2012, 03:18 AM   #29
Ah... the dust. I think that I mentioned that earlier, but no matter -- a vacuum attached will do wonders (if it is possible).
Here is something I am still trying to find the time to make -- a Router Trammel. There are professional ones that you can buy, but it always looked simple enough to make this.
Router Trammel ? DIY How-to from Make: Projects
You can get the professional/mass-produced circle cutting jigs and they are easy to use (just make sure they can go down to 2 inches).
You might want to check this guy out. He makes speaker boxes for cars and he has some good ideas.
Using a Router to Cut Perfect Circles, part 1 - YouTube
He has a few videos (5 or 6) on cutting circles out of MDF.
So far I have been making small holes (4 inches I think is the smallest I have made) just by plunging the router down into the material and having a template and a plunge trim router bit. But at 2 inches, you might be best off using a drill and a hole cutting bit for the drill.
Don't be too discouraged by the selection of bits, you probably have enough of the important ones to do the job of speaker cutting and building. You might have a hard time finding all the profile bits for making things like picture frames with fancy profiles, but have enough to cut holes, joinery, and make straight line cuts.
Old 9th October 2012, 11:29 PM   #30
dangus is offline dangus  Canada
I disagree on the second-hand router thing. I bought my well-used 1/4" B&D Pro (Elu) from a pawn shop for $35; all I did was make sure that the bearings were OK and that it ran, and that the rack & pinion depth adjustment adjusted. No problems at all. Recently I picked up a similar model (but orange) at a garage sale for $40, nearly unused (complete with carrying case and accessories).
Routers make a lot of dust, but they are the only power tool you need for speaker building. Other than a driver drill.
Dremel Trio ... sufficient tool?Hide this!Advertise here!
PCB drilling with a dremel Krisfr Construction Tips 33 8th January 2011 02:43 AM
Jobmate Dremel - For Canadians EdT Everything Else 0 22nd February 2007 07:00 PM
Is the 1.1A diode sufficient? w00t Chip Amps 2 16th August 2004 06:52 PM
Demagnetising Tool/Tool Demagnetiser mrfeedback Everything Else 30 5th October 2002 12:53 AM
Tools? Dremel or Rotozip? Pyro Equipment & Tools 7 16th March 2002 04:43 PM
Copyright ©1999-2017 diyAudio
