Equipment & Tools From test equipment to hand tools
WinAudioMLS, A Powerful analyzer
Old 13th September 2012, 06:22 AM   #1
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Default WinAudioMLS, A Powerful analyzer
I recently purchased a non-commerical version of WinAudioMLS. It is a very powerful tool. In order to support this powerful tool, a decent audio interface is needed. We can buy off-the-shelf USB audio interface supporting 24-bit, 192 kHz. Not all of them give you best analog performance.
Here is my plan: USBStreamer from miniDSP + home made high-performance analog front. USBStreamer is based on XMOS USB audio solution. It supports 24-bit, 192 kHz streaming. Driver of USBStreamer supports ASIO. High-performance 24-bit, 192 kHz ADCs are available from Digikey, Mouser, etc. We can add opamp signal conditioning circuit and attenuator to have a complete analog front end. Currently, I using WM8788 for evaluation. Here is WinAudioMLS and USBStreamer running at 96 kHz sample frequency. Input of WM8788 is connected to a 1 kHz low-distortion signal source.
FFT shows harmonics of 60 Hz mains. 8 kHz and 16 kHz are external interference.
Old 13th September 2012, 08:55 AM   #2
panson_hk's Avatar
I set the USBStreamer in loopback mode where output ch1&2 connected to input ch1&2. Hence, we can test the system performance limit.
Red curve is standard FFT and Cyan curve is 64-bit FFT. SNR improves significant with 64-bit computation.
Old 15th September 2012, 01:59 PM   #3
1audio is offline 1audio  United States
That looks like digital loopback. No analog system will get that good that I have seen. The Minidsp stuff is well done.
Demian Martin
Product Design Services
Old 15th September 2012, 11:11 PM   #4
panson_hk's Avatar
Yes, it is loopback at I2S in/out of USBStreamer. It can be used as reference to evaluate attached analog performance.
Old 23rd September 2012, 09:24 PM   #5
Boscoe is offline Boscoe  United Kingdom
What are the distortion figures?
Audio projects and more: gswdh.co.uk
Old 25th September 2012, 09:33 PM   #6
skidave is offline skidave  United States
skidave's Avatar
As Boscoe said, what are the distortion figures. Did you try his signal generator with this software as well (the free one)?
Old 26th September 2012, 03:20 AM   #7
panson_hk's Avatar
Here is THD of loopback.
Right figure: default setting, THD+N = 0.0077%, THD = 0.0027%
Left figure: 64-bit FFT, THD+N = 0.0008 %, THD = 0.0000 %
Old 26th September 2012, 03:30 AM   #8
panson_hk's Avatar
The free one seems to have poor performance as shown in the figure. It has much higher noise floor and frequency offset.
Frequency was set to 777 Hz.
Old 26th September 2012, 03:50 AM   #9
panson_hk's Avatar
Default Windows function affects THD result
The choice of FFT window function affects the THD result.
Left: THD+N is -105 dB for Blackman window.
Right: THD+N is -144 dB for Rife-Vincent window.
Both are with 64-bit FFT enabled and looback.
File Type: jpg WinAudioMLS_THD_64bit_Rife-Vincent.jpg (384.3 KB, 114 views)
Old 26th September 2012, 03:52 AM   #10
panson_hk's Avatar
I am working on a front-end board for this test setup.
WinAudioMLS, A Powerful analyzerHide this!Advertise here!
Oscilloscope as Spectrum Analyzer/Frequency Response Analyzer sameerdhiman Equipment & Tools 18 9th June 2011 08:19 PM
Most powerful amps highpow3rpc Solid State 0 6th December 2009 12:41 PM
Powerful bass syl Solid State 13 2nd July 2007 10:29 PM
Most Powerful Opamp avaliable soundNERD Chip Amps 28 26th March 2006 04:40 PM
simple but powerful sr2002 Chip Amps 19 1st August 2005 06:20 PM
Copyright ©1999-2017 diyAudio
