Equipment & Tools From test equipment to hand tools
Schematic for Microvoltmeter / add-on for Oscilloscope
Old 20th August 2012, 02:13 PM   #1
LinuksGuru is offline LinuksGuru  Europe
Default Schematic for Microvoltmeter / add-on for Oscilloscope
Hi !
Anyone can suggest schematic (or may be finished products), which could function as micro-voltmeter (with sensitivity starting from 10-3o uV) or even better, add-on for oscilloscope with frequency response 10 Hz - 300 KHz?
Thanks in advance for any suggestion(s).
Old 20th August 2012, 02:19 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
30uV? That's no sinecure! When I needed one I bought one of those B&K measurement amplifiers on eBay.
Came with all kinds of filters and peak, average, RMS etc detectors as well.
30uV fsd on the most sensitive scale, with wide band noise less than 10% of that.
jan didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 20th August 2012, 06:06 PM   #3
Samuel Groner is offline Samuel Groner  Switzerland
At this amplitude level you probably want differential inputs and adjustable bandwidth-limiting filters. Some commercial products:
Tektronix AM502
Tektronix 7A22 (if you have a 7000 series scope)
Princeton Applied Research (PAR, also EG-G) 113
Stanford Research Systems (SRS) SR560
I have the first three models, all work very well. I'm mostly using the 7A22 as the scope readout conveniently gives the correct deflection factor.
You can quite easily build a simple differential preamp based on an IC mic preamp chip, e.g. a THAT1510. If you need super low noise and can live with just a single-ended input, check out my low noise preamp (A low noise laboratory-grade measurement preamplifier and SG-Acoustics · Samuel Groner · Publications).
Samuel
Old 21st August 2012, 05:47 AM   #4
Frex is offline Frex  France
Post ERMSDCV2
Hello LinuksGuru,
Maybe you can take a look HERE and HERE.
It's a PCB design for DC..1MHz RMS/DC converter, with high performance low noise
amplifier. It allow to measure noise down to µV, and periodic signal down to 100nV using scope averaging. The bandwidth of LNA is 10Hz-100kHz, that seem near of your needs.
Regards.
Frex
Old 22nd August 2012, 07:49 PM   #5
Samuel
Hi, Samuel !
Thanks a lot for feedback!
I have a few of questions:
1) What is minimum measurable input signal level?
2) What is minimum input signal level which then could be examined on oscilloscope (so noise and distortions of pre-amp will be small comparable to DUT)?
3) Is this article published in the last (#3) issue of Linear Audio?
4) I saw on your web site (very professional and informative btw) comparison of different film capacitors technologies. What methodolgy/Equipment you have used to measure so low level of distortions produced by passive components?
Thanks !
Old 23rd August 2012, 09:12 AM   #6
You have not given any details of your application--without context it's hard to define a "minimum measurable signal". What does the signal look like? What parameter of it do you need to measure?
Viewed on a scope without bandlimiting filters, the output noise of the preamp is about 2 mVpp. Referred to the input (60 dB or 1000x gain) this makes 2 uVpp. With a 100 kHz bandwidth-limiting filter this improves to 600 uVpp (RTI 600 nVpp). These are extremely low figures, and in most cases the noise of the source, or interference, will dominate.
Yes, as noted on my webpage.
4) I saw on your web site (very professional and informative btw) comparison of different film capacitors technologies. What methodolgy/equipment you have used to measure so low level of distortions produced by passive components?
Well, distortion of some passives (e.g. polyester film) is not that subtle and can be easily measured with a good audio analyzer (I use an AP SYS-2722). More refined techniques involve indirect measurement by comparison with a "known good" part (e.g. a capacitor which is synthesized by several larger capacitors in series; in such an arrangement each capacitor sees much lower AC voltage drop, which drastically reduces its distortion). The classic method is the use of a bridge setup, but there are others.
Samuel
Old 23rd August 2012, 10:46 AM   #7
Hi, Samuel,
Basically it is for measurement noise and low-level oscillation (if any) of power amps, pre-amps, and possibly, DACs. I'm going to build DAC with ESS Sabre,
ESS and following op-amp are extremely low-noise devices, so measuring noise is quite a challenging task.
Old 24th August 2012, 07:25 PM   #8
Basically it is for measurement noise and low-level oscillation.
These are completely different things. For the latter you need a BW well into the upper MHz region. Most oscillations are detectable without any additional preamp, and I'm not sure how much a preamp helps for those which aren't--in such a high measurement bandwidth noise quickly limits things. Probably a 10x preamp is of some use.
To measure noise my low noise preamp is very suitable; with a noise contribution of 0.4 nV/rtHz you will hardly find a situation where it contributes significantly to the measurement. But you need band-limiting filters after it to define the measurement bandwidth (unless you're using FFTs).
The design by Frex has those built in; however, the input resistance of this preamplifier is very low (100r IIRC) such that it is difficult to apply in many circumstances. And its noise contribution is higher.
Samuel
Old 2nd September 2012, 11:27 AM   #9
Hi, Samuel,
What is the upper frequency limit of your pre-amp?
On your sire it is stated 100 KHz, on Linear Audio web site - 1 MHz.
I don't care about small non-linearity.
Once I had nasty oscillation several mV at 200 - 300 KHz region, it was quite difficult to track it with digital oscilloscope, so upper bandwidth limit sometimes may be important.
Old 2nd September 2012, 12:23 PM   #10
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I will second Sam on the 7A22N -- (although I use a 5A22n on a 5223 scope). You can find the manual for the 7A22N on the "Boat Anchor Manual Archive" http://bama.edebris.com/manuals/tek
It's not too difficult to build an amplifier with existing IC's like the AD797 or LT1028 -- just power it off a pair of 9V alkalines.
Schematic for Microvoltmeter / add-on for OscilloscopeHide this!Advertise here!
Levell TM3b microvoltmeter big jim Parts 24 12th August 2009 07:54 PM
levell microvoltmeter big jim Parts 1 28th April 2009 05:33 PM
how do i add speaker protection to this schematic prorms Solid State 1 6th October 2006 06:36 PM
Oscilloscope schematic? DigitalJunkie Equipment & Tools 1 26th January 2006 03:12 AM
