Equipment & Tools From test equipment to hand tools
How to remove wire insulation?
Old 15th August 2012, 12:21 AM   #1
mrjayviper is offline mrjayviper
Default How to remove wire insulation?
My denon headphones has a broken wire at the top of the plug. I cut it open and the left/right wire are covered in some sort of "tin" that makes solder hard to stick to it.
Any suggestions to my problem? Thanks. ☺☺☺
Old 15th August 2012, 01:58 AM   #2
tvrgeek is offline tvrgeek  United States
flux
Are you sure the wire is not aluminum?
Old 15th August 2012, 03:00 AM   #3
It's copper underneath if I try very hard scraping it off. The "tin" is colored metallic blue for left channel and metallic red for right.
Old 16th August 2012, 03:26 PM   #4
thermal runaway is offline thermal runaway  United Kingdom
thermal runaway's Avatar
Sounds like it's enamelled copper, only way to remove it is by scraping it off.
Old 16th August 2012, 11:06 PM   #5
phaselag is offline phaselag  United States
On most enameled wire it is removed by using solder. The heat causes the insulation to burn or melt off. Get a blob of molten solder on your iron and hold the end of the wire in the molten blob. After several seconds the insulation will be gone and the wire tinned.
paul
Old 16th August 2012, 11:24 PM   #6
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
If it is copper wire with a kind of "shine-through" lacquer on it that would be enameled wire. In other words: wire with a thin but very sturdy lacquer. BTW it is a surprise every time to see native english speakers express so non precise. Please rephrase it to make things really clear.
If it is enameled wire :scrape the enamel off all around the wire and pre-tin the wire,then solder it to the connector. Simplest way would be scraping it off with a knife as the material is hard but brittle. It will not disappear easily with solder. You will have to have a clean copper surface for good soldering and a good connection.
A tin ?!
It's only audio. Member of the non modular PCB design committee
How to remove wire insulation?Hide this!Advertise here!
Favorite Speaker Wire -- Part 2: Insulation Bob Brines Full Range 37 4th February 2010 06:49 PM
Wire Insulation for Wire stator Audio_idiot Planars & Exotics 6 25th May 2007 12:42 PM
Need insulation for 16 ga. solid core wire for PC tom1356 Everything Else 44 26th December 2006 04:07 PM
What is the most easy way to remove protection from copper wire luka Parts 12 27th September 2005 09:12 PM
copper wire insulation remover chemical himanshuraval Everything Else 10 13th July 2004 03:46 AM
Copyright ©1999-2017 diyAudio
