Equipment & Tools From test equipment to hand tools
Speaker Workshop doesn't like my Behringer UCA202
Old 10th July 2012, 12:34 PM   #1
68Spider is offline 68Spider  United Kingdom
Default Speaker Workshop doesn't like my Behringer UCA202
I'm just getting started with my first speaker project but have hit a problem with my USB sound card, a Behringer UCA202. Going through the calibration mode of Speaker Workshop I see the attached plot. I understand that this indicates the UCA202 is a cheapskate card that duplexes the L/R channels giving bad phase distortion. Is there anything I can do about this or should I be looking at getting a new sound card?
Old 15th July 2012, 11:30 AM   #2
dangus is offline dangus  Canada
It's supposed to be based on the same TI/Burr-Brown chip that's found in some much more expensive hardware. Maybe an ASIO driver will make a difference?
Old 15th July 2012, 10:56 PM   #3
whizgeek is offline whizgeek  Ireland
Also check the sample rate>48000 , and play with the latency values if you can.
Old 6th August 2012, 04:26 PM   #4
ctrlx is offline ctrlx  United Kingdom
that curve is ok...
you put in a value for "int ch delay" to comp and get the phase flat.
Old 21st May 2013, 01:04 PM   #5
I had to abandon working on this due to other commitments but have just found some time to play with it again.
I had tried before to alter the channel delay, to no good effect but this time around I figured out that I should try a negative value. Bingo! A -21.15 delay was enough to get the phase response almost flat - just -2 degrees out at 20KHz.
Old 21st May 2013, 06:03 PM   #6
A bit more tweaking and it looks to be almost completely flat using a channel delay of -20.91 uSec.
Speaker Workshop doesn't like my Behringer UCA202Hide this!Advertise here!
Re-Jigging the jig: Speaker testing device for Arta, Speaker Workshop & HOLMImpulse MJL21193 Multi-Way 264 8th October 2012 01:10 AM
BEHRINGER UCA202 RCA output coupling cap mod ?? AC439 Digital Line Level 4 15th June 2012 08:53 PM
Behringer FCA202 and UCA202 soundcards noodle_snacks Digital Source 2 6th August 2006 10:17 PM
Speaker Workshop, help please Grahamt Multi-Way 5 10th March 2005 12:48 PM
Speaker Workshop do all this? rick57 Multi-Way 8 20th November 2004 03:11 PM
Copyright ©1999-2017 diyAudio
