Equipment & Tools From test equipment to hand tools
Fluke 8520A reading drifts
Old 24th June 2012, 11:25 PM   #1
johngalt47 is offline johngalt47  United States
Default Fluke 8520A reading drifts
I bought this 5 1/2 digit meter a few years ago and it is ok except that trying to read microvolts is impossible. For example, this afternoon it is drifting from .2 to .5 mV DC and won't "sit still" no matter what.
Could it be an A/D or D/A converter or ???
Any technology sufficiently advanced is indistinguishable from magic
Old 24th June 2012, 11:33 PM   #2
DF96 is offline DF96  England
Microvolts AC can pick up hum fields. Microvolts DC can get thermoelectric or contact potential effects.
Old 24th June 2012, 11:36 PM   #3
Ok, so what method should I use aside from building a Faraday cage to combat the effects of hum from other sources?
Old 24th June 2012, 11:49 PM   #4
For low level AC you need filtering, so the meter only sees the signals you are interested in. As well as hum there is also all the RF around in a typical location. 3 1/2 digits is good enough for most purposes, and don't believe any figures below a few mV.
Old 16th July 2012, 09:41 PM   #5
lepomis is offline lepomis  United States
I have that same unit. I don't have a drift problem with either AC or DC. However, I have no idea if those last few digits are correct or not Does the unit pass it's 'self test' ?
Old 16th July 2012, 10:33 PM   #6
I don't know...I've never run the self test. I will say that on lower value resistors it is rock solid.
Old 16th July 2012, 10:52 PM   #7
asmith is offline asmith  United States
I bet your in a high RF area, and thats what it's reading. Try shorting the inputs, right at the input and see what it reads.
Fluke 8520A reading driftsHide this!Advertise here!
B+ Drifts down after 2 hours Anchan Tubes / Valves 12 5th December 2011 02:48 AM
Fluke 8502A? nania Parts 5 22nd May 2010 04:29 AM
Fluke 1900A jblmar Solid State 3 25th October 2007 07:50 PM
Get a Fluke DMM ThSpeakerDude88 Parts 107 21st August 2007 01:40 AM
