Equipment & Tools From test equipment to hand tools
Just bought Aoyue 936, now what solder to buy?
Old 4th June 2012, 12:55 PM   #11
On Hiatus
SY's Avatar
I've used both sponge and brass wool- the brass wool seems to be a bit more effective, but they're both fine. For a decent soldering iron, the temperature recovery is pretty fast (seconds) so I wouldn't worry about that.
For solder, 60/40 is good, 63/37 is even better, and a 2% silver solder (rosin core in all cases) will give you super-looking joints and not leach silver from components that have silver-bearing terminations.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th June 2012, 04:09 PM   #12
qusp is offline qusp  Australia
qusp's Avatar
its not the thermal recovery thats the problem, its the sudden and repetitive thermal cycling of the tip and the oxidization caused by the wet sponge.
Old 6th June 2012, 07:00 PM   #13
marce is offline marce  United Kingdom
Second 63/37 true eutectic tin lead, best to practise on as it flows easy. 2% silver (Tin/Lead/Silver) is what I use, as I have a great big real of it from a project that required silver solder, gives nice shiny joints.
If you do SMD though solder choice can depend on components and terminal finish, a lot of new components are matt tin, for reflow tin lead on these components is not as good as using a lead free solder.
Old 6th June 2012, 11:19 PM   #14
DreadPirate is offline DreadPirate  United States
DreadPirate's Avatar
Kester 63/37 in the .032 diameter.
Old 6th June 2012, 11:41 PM   #15
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Be careful, when changing the tips on those excellent irons, sometimes they dont want to screw back on correctly due to cheap plastic threads. Otherwise phenomenal iron for the price.
...Shape the sound , Man!
Old 21st June 2012, 10:41 PM   #16
klewis is offline klewis  United States
klewis's Avatar
I've used WBT -0820 which has silver content. It flows very well. However, the price has just exploded... Still I tried another eutectic (sp?) solder and have not been as happy, it tends to stick to the tip more and pull the puddle as you remove the iron. The WBT flows very well, making smooth neat joints.
Old 21st June 2012, 10:52 PM   #17
hags is offline hags  United States
If you're budget minded try this:
Dayton Audio SLDR-S4P-8 4% Silver Solder 1/2 lb. Spool 370-038
It compares favorably to WBT, Wondersolder etc.....
If you want the absolute best, in my opinion, for ease of soldering, flow, low melting point, great looking joints etc... then try this:
Cardas Audio
Without a doubt the finest I have used and I've tried most of them.
"Some lures are designed to catch fish, others are designed to catch fisherman."
Just bought Aoyue 936, now what solder to buy?Hide this!Advertise here!
Best solder? where to buy? stargeezerme Equipment & Tools 32 29th February 2012 04:03 AM
Hakko 936 - is this a good deal? kingby Equipment & Tools 3 27th January 2010 05:31 PM
Tips for Hakko 936-12 Dido Tubes / Valves 7 20th December 2005 02:55 PM
Hakko 936-12 TheDriver41 Equipment & Tools 7 24th October 2004 01:52 AM
Group buy on Sn96.5 Ag3.5 solder... dkemppai Swap Meet 5 12th December 2003 03:26 PM
Copyright ©1999-2017 diyAudio
