Equipment & Tools From test equipment to hand tools
Surface covering for Work bench. Help!!
Old 11th May 2012, 09:03 PM   #11
diy didi is offline diy didi  South Africa
Thanx for all the suggestions. Think I'm going with Enzo's advice. Just a piece of carpet I can shake out to clean.
Old 11th May 2012, 09:11 PM   #12
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Originally Posted by tvrgeek View Post
I don't like carpet as it holds things. Fne on the shelves though. I use a piece of anti-static mat. Soft rubber. Easy to clean and, anti-static.
ESD Workstation Mat | Computer Mats | Conductive Mats by allMATS.com
The anti static mat is best for working on electronic gear. Keep a brush around to sweep it off and clean the dirt off with soap and water every few years YMMV
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Surface covering for Work bench. Help!!Hide this!Advertise here!
Covering bass ports? revans Everything Else 7 17th April 2009 10:10 PM
Great bench supply for tube work. gearheaddruid Tubes / Valves 25 21st August 2007 10:54 AM
fiberglass baffle covering Ang Multi-Way 3 15th April 2007 03:01 AM
Help with surface mount work eeka chu Solid State 1 13th May 2004 02:39 AM
Audio Work Bench Mark A. Gulbrandsen Everything Else 7 9th March 2004 03:47 AM
