Equipment & Tools From test equipment to hand tools
crimping tool crimper
Old 20th April 2012, 10:28 AM   #11
These look like the crimper used to "crush" the receptacle around a single cable, usually stranded. Used for creating an air free metal to metal contact inside the receptacle.
These would never be used for a coax.
regards Andrew T.
Old 22nd April 2012, 12:02 PM   #12
dangus is offline dangus  Canada
The 8" crimper is the way to go. That same tool is sold under umpteen brand names (T&B, Klein). It has plenty of leverage. In a pinch there are some stamped crimp tools that are almost tolerable: I got one at an autoparts store because it had the ignition wire terminal crimp on it. And the stamped Molex crimp tools are fine if you need that style.
For stripping, I use a K. Miller model 100 stripper/cutter (like the Klein 1003); you can leave it adjusted for small gauges and judge the pressure by feel, so strip any size wire without worrying about which notch to use, or adjusting the setting.
Old 23rd April 2012, 01:58 PM   #13
cliffyk is offline cliffyk  United States
cliffyk's Avatar
Harbor Freight has a nice full compression crimping tool that is often on sale for $10, and is currently on sale for $7. I have a couple and find they are well and accurately constructed.
Old 24th April 2012, 12:43 AM   #14
Speedskater is offline Speedskater  United States
Speedskater's Avatar
I also have one of the Harbor Freight crimping tools in my electrical tools -toolbox.
Kevin
Old 21st August 2012, 04:29 AM   #15
fakeout is offline fakeout  Canada
fakeout's Avatar
Well, thanks everyone for the help. At one point, I bought a cutter/stripper thinking I would get a crimper later on. I couldn't find one that I wanted to buy. So, I ended up returning the cutter/stripper and bought a cutter/stripper, crimper; the Gardner Bender GESP-70.
GARDNER BENDER (GB ELECTRICAL) GESP-70 8-24 WIRE STRIPPER - Tool Catalog - Electrical - Electrical Hand Tools
I works. The only thing I didn't know from the start though is that it seems better to crimper with the round part the side of the fold of the terminals. At least I first tried on a cheap pair of drivers.
Feeling Good by David Burns
Old 21st August 2012, 01:20 PM   #16
w1jim is offline w1jim  United States
Originally Posted by fakeout View Post
Or, would it be acceptable to use a Vise-Grip or needlenose plier to crimp?
Never , unless you're on a deserted island and need it to get your car running.
I can fix it but good!
Old 21st August 2012, 01:26 PM   #17
Einric is offline Einric  United States
Einric's Avatar
I use those cutter/crimpers on a daily basis at my job.
I have a separate set of T-Strippers, 2 sets to cover 28awg to 10awg.
I find that I have much lower warranty rate when I have a dedicated stripper because it is much better built and doesn't nick the wires or accidentally cut strands off.
crimping tool crimperHide this!Advertise here!
Insulated terminal crimper 454Casull Parts 1 31st May 2009 11:28 PM
Lead bender/crimper d3imlay Parts 0 19th January 2007 03:29 AM
An Experts Guide to Crimping !!! wytco0 Parts 20 14th October 2004 03:39 AM
Crimping VS. soldering Magura Equipment & Tools 62 10th May 2004 03:57 AM
Demagnetising Tool/Tool Demagnetiser mrfeedback Everything Else 30 5th October 2002 12:53 AM
Copyright ©1999-2017 diyAudio
