Equipment & Tools From test equipment to hand tools
Measuring ultra high voltages with DMM
Old 14th April 2012, 10:54 AM   #1
Alexontherocks is offline Alexontherocks  Italy
Default Measuring ultra high voltages with DMM
Dear all. I have a few questions i haven't found answers to.
I am working on filtered 2kv anode voltages and have achieved filtering with series capacitors. Everything works and the caps are balanced. The problem is i have a 500v max dc dmm. I have used it across one of the five series capacitors to estimate (x5) the overall voltage. So i get 400v and estimate that the whole bank sees 2kv across it.
On to the questions:
1 can this method be applied to an oscilloscope?
2 what is the reliability for this kind of method forripple and voltage values?
Inviato dal mio GT-I5800 usando Tapatalk
Old 14th April 2012, 11:11 AM   #2
Mooly's Avatar
You can't really use a scope because normally the scope probe ground would apply a "short" to chassis ground across the caps. That is if both scope and equipment are grounded.
To have the scope "floating" is dangerous and can still give unexpected results due to capacitive/inductive coupling.
Safest method is a proper high voltage probe. You can just use series resistors (but you need several so as not to exceed the voltage rating of the resistors).
Somerthing like this. You don't need the frequency compensation for looking at low frequency ripple. The resistor R1 in this example MUST be either a high voltage resistor rated for what you need or made up of several lower values in series.
That would allow you to measure the ripple on the 2KV rail. 2KV isn't ultra high
How to make a 100X oscilloscope probe - a great resource for How To's from Wikia
Old 14th April 2012, 12:16 PM   #3
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Here is a good reference for high-voltage multimeter probe design. I'm not sure how well enclosures are addressed; I'd probably put it in something like a foot long piece of 3/4" PVC pipe.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 14th April 2012, 12:21 PM   #4
miklos is offline miklos  Hungary
miklos's Avatar
Default Try one of these:
high voltage probe | eBay
miklos
Old 14th April 2012, 12:26 PM   #5
miklos's Avatar
Or make your own HV probe with the help of these:
high voltage resistor | eBay
miklos
Old 14th April 2012, 12:33 PM   #6
miklos's Avatar
You can't divide HV with series connected capacitors, you have to use resistors.
miklos
Old 14th April 2012, 12:52 PM   #7
Thanks everyone. 2kv is quite high for an active device like an amplifier but i get the point. As for the capacitors these all have balance resistors. Results measuring across one cap and multiplying gives just about the exact result from psudII.
Old 14th April 2012, 12:57 PM   #8
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Just be careful with NOISE.
I built a HV probe for my oscilloscope, OK it was to work at 40KV but it was useless.
The noise picked up by the chain of high value resistors made it unworkable.
Old 14th April 2012, 01:19 PM   #9
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
You might want to check around for local HAM radio freaks as a lot of them use the HV stuff in their radio transmitters and thus need measuring gear.
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 14th April 2012, 02:16 PM   #10
LafeEric is offline LafeEric  United States
LafeEric's Avatar
I once made a 165KV voltage divider using a bunch of high ohm resistors and one precision resistor.
It was all just ohm's law. I figured out the resistance needed for 30uA @ 165KV and found a high ohm 5 watt 5% resistor to build my ladder. I think the max voltage on each was about 1200V. I measured each individual resistor as I added it and kept track on a spreadsheet. There were a bunch, I forget just how many right now, but because my ladder resistors weren't that special the cost wasn't that much.
The last resistor, which was the one actually measured across, was .1 % @ 2 watt, if I remember correctly. I figured out my overall precision was about 2%, which was acceptable. The bottom of the probe was grounded, which allowed O-scope measurement. Solder joints were all carefully smoothed, and the whole thing was dipped multiple times in corona dope, then mounted in a plexi tube about two feet high.
Measuring ultra high voltages with DMMHide this!Advertise here!
High voltages akis Tubes / Valves 8 30th November 2010 10:49 PM
measuring voltages and currents simple se pforeman Tubelab 1 10th August 2009 02:38 AM
Headphone Line-Out Voltages - (Newbie DMM AC Voltage Reading) trelin Headphone Systems 7 9th May 2008 07:15 AM
ST35 voltages WAY too high! ThSpeakerDude88 Tubes / Valves 13 14th April 2008 08:50 PM
Measuring subwoofer amps power with DMM(and other questions) xstephanx Subwoofers 8 10th March 2005 05:14 AM
Copyright ©1999-2017 diyAudio
