Equipment & Tools From test equipment to hand tools
Measure sensitivity
Measure sensitivity
Old 6th April 2012, 09:57 AM   #1
t0mm1 is offline t0mm1
Default Measure sensitivity
Some newbie questions:
I don't find any specs for my old 4" drivers and I need to measure the sensitivity since I'm going to replace them.
The impedance is 4 ohm.
I have a multimeter, a dB-meter and a 1 kHz sine wave sound source.
If I have done my math correctly, I have to measure 2V with my multimeter to get 1W out from my driver.
Two questions:
1. Should I measure DC voltage or AC voltage?
2. Should the driver be in its cabinet or outside while measuring?
Thanks!
Old 6th April 2012, 10:03 AM   #2
Maybe it is 1.414V DC or 2V AC I should measure?
Old 6th April 2012, 10:06 AM   #3
d a o is offline d a o  Denmark
Hi t0mm1,
You need at Sound SPL meter, Lin, A or C for 1 kHz
Always AC in Audio
A ISO baffle but can't find a link
Old 6th April 2012, 10:40 AM   #4
Originally Posted by d a o View Post
Hi t0mm1,
Always AC in Audio
OK. AC then. Have I done my math correctly; 2V?
Old 6th April 2012, 12:30 PM   #5
I measured 2V rms with my oscilloscope (since I think multimeters are designed for 50Hz)... and I only got about 50dB on 1 meter. I'm doing something really wrong I believe ;-)
Old 6th April 2012, 12:48 PM   #6
2Vrms on an oscilloscope?
How?
Oscilloscope displays waveform.
The waveform amplitude is generally read as a peak to peak voltage (Vpp).
For a sinewave signal the Vpp to Vrms conversion factor is 2*sqrt(2) ~ 2.83.
That 2.83 factor is equivalent to 9dB
If you read 2Vpp from the scope then you need to add 9dB to your SPL reading to give a sensitivity @ 1kHz of ~59dB/2V @ your monitoring distance.
Alternatively, increase your test signal from 2Vpp to 5.7Vpp
regards Andrew T.
Old 6th April 2012, 12:55 PM   #7
How?
Thge waveform amplitude is generally read as a peak to peak voltage (Vpp).
My HP 54600B calculates V p-p, V rms and V avg.
So, having a 1kHz sine wave and measuring the line I adjusted the volume until the scope said 2V rms.
Maybe I'm doing it wrong?
Old 6th April 2012, 12:55 PM   #8
Wideband signal rather than a single frequency test signal.
But then you need and rms reading voltage meter to set the input signal.
regards Andrew T.
Old 6th April 2012, 01:23 PM   #9
I think it might be better to let some professionals measure it instead... there are still too many factors that can ruin the results for a newbie like me ;-)
Old 6th April 2012, 02:42 PM   #10
Hi t0mm1,
Always AC in Audio
Watt = P = U^2 / R
Watt = P = U * I
Watt = P = R * I^2
You need at True RMS AC volt meter to atleast 1 kHz
IEC Baffle and a SPL meter placed 1 meter in front of speaker
To get the RMS out of a Peak 2 Peak SINUS value = a / SQR(2) : Where "a" is amplitude (peak value)
http://en.wikipedia.org/wiki/Root_mean_square
It should actually do it for you
Measure sensitivityHide this!Advertise here!
Sensitivity pjanda1 Wild Burro Audio 2 12th December 2009 01:54 AM
sensitivity = quality? nukaidee Multi-Way 4 20th March 2009 04:35 AM
driver sensitivity vs system sensitivity bvan Full Range 12 5th November 2007 08:57 PM
Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? rhythmdiy Multi-Way 5 5th November 2007 12:33 PM
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 10:18 PM
Copyright ©1999-2017 diyAudio
