Equipment & Tools From test equipment to hand tools
Any way to test an ECM8000 yourself?
Old 27th March 2012, 01:14 AM   #1
JZatopa is offline JZatopa  United States
Default Any way to test an ECM8000 yourself?
I was wondering if there is any way to check the accuracy of a ecm8000 without sending it out to be calibrated.
Old 27th March 2012, 02:39 AM   #2
Pano is offline Pano  United States
Pano's Avatar
You could compare it to a known omni-directional mic; that's basically what calibration is.
Some folks have had luck comparing it to a known driver, like a high quality tweeter.
It's the top and the bottom of the range that need to be checked.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 27th March 2012, 03:11 AM   #3
I have a pair of mackie hr624 studio monitors, do you think they are good enough to use as a reference?
Old 27th March 2012, 03:31 PM   #4
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
Is the frequency response of the mackies well documented somewhere?
I think Pano meant measure a driver that has been measured by various people and compare your measurement to those.
Old 27th March 2012, 08:04 PM   #5
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Before you start checking mic response curves, read how Earthworks does it.
http://www.earthworksaudio.com/wp-co...sures-mics.pdf
Kevin
Old 31st March 2012, 11:48 AM   #6
tvrgeek is offline tvrgeek  United States
Just have it done. They vary a lot more than you think. Once I had one done, I did a "close enough" on my second one and my home made Panasonic. I did not pay the extra for phase response as at that time my design work was not that complex. Wish I had but it is a lot more money.
You can't use ANY published frequency response of a speaker at home. I would suggest doing a lot more reading, like "Testing Loudspeakers" By John D.
Old 31st March 2012, 12:18 PM   #7
Ron E is offline Ron E  United States
Ron E's Avatar
You could read up on reciprocity calibration.
Use a headphone element as the auxiliary transducer and measure a tweeter.
Basically measure any tweeter with your mic and the headphone element (used as a mic) then measure the headphone element (used as a speaker) with your mic. There is some math, but you get a primary calibration. I have done it (very roughly - mics sitting on a table) using a cheap radio shack dynamic omni microphone instead of a headphone transducer - the results weren't great, but promising enough to try it again with a more elaborate setup.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 31st March 2012, 12:24 PM   #8
If you need it within a couple of dB, have it done. Period. $60
Any way to test an ECM8000 yourself?Hide this!Advertise here!
Preamp for ecm8000 ZeNmAc Equipment & Tools 11 26th January 2011 01:57 PM
ECM8000 Microphone Twisted85 Multi-Way 47 23rd March 2010 11:03 AM
Another ECM8000 Question. samsagaz Multi-Way 10 9th March 2007 09:38 PM
WTB: ecm8000 mic sqlkev Swap Meet 1 2nd March 2006 03:17 AM
Behringer ECM8000 interface maylar Instruments and Amps 1 13th March 2004 05:17 PM
Copyright ©1999-2017 diyAudio
