Equipment & Tools From test equipment to hand tools
White Noise Generator
Old 28th March 2012, 05:48 PM   #11
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
A 604K resistor and just about any FET op-amp (or a JFET follower for that matter) makes a nice 100nV/root-Hz white noise.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 28th March 2012, 11:27 PM   #12
Simon B is offline Simon B  United Kingdom
Temperature compensation is left as an exercise to the reader....!
Old 29th March 2012, 12:41 AM   #13
Andrew Eckhardt is offline Andrew Eckhardt  United States
At one time I was looking for highest noise volts out for minimum microamps in and I wound up with 1M into a revered biased 3904 base emitter junction feeding a mu follower. Drawback is you need at least 10V supply to make it practical. More than a 9V battery except brand spanking new, anyway.
Old 29th March 2012, 03:59 AM   #14
Pretty weak variation around room temperature, though in the UK it is probably noticably lower.
Old 29th March 2012, 08:18 AM   #15
benb is offline benb  United States
Originally Posted by LAJ View Post
I built one of those before but using an op amp for the amplifier. I didn't think it worked very well.
But from the National Semiconductor 1980 Audio/Radio manual page 2-62 it states:
Unlike semiconductor noise sources, the MM5837 provides very uniform noise quality and output amplitude.
The MM5837 uses a clocked shift register to generate noise which I thought was a much better approach.
The chip's output is "uniform" because it repeats every couple of seconds. If you measure its peak output for a few seconds, you've measured the highest peak output it will ever give. It's like a two-second tape loop of recorded noise that gets played back over and over (once you hear it loop through a few times it actually SOUNDS like a two-second tape loop of recorded noise). This can be useful when you want to make the noise drive something to just below clipping, and need to know that it will never clip. With an analog noise source it may eventually clip, as the level is "truly" random and you don't know what the peak may be.
Here's a description of a PIC microcontroller replacement:
White Noise Source based on PIC 12F processor
The PIC code described is "better" in that it has a much longer period, but once gain that's not always what you want.
Old 31st March 2012, 01:25 PM   #16
tvrgeek is offline tvrgeek  United States
I just use my PC. White, pink, whatever. Want it portable? Make a CD.
White Noise GeneratorHide this!Advertise here!
White noise problem Kei Solid State 4 1st February 2012 08:35 PM
Computer white noise generator, which software? Bricolo Everything Else 16 6th April 2010 12:50 AM
White Noise, Protruding woofer Code Class D 6 16th January 2008 07:02 PM
HELP: White or Pink noise problem Tedyp Parts 2 26th March 2006 11:42 PM
Copyright ©1999-2017 diyAudio
