Equipment & Tools From test equipment to hand tools
Lepai 2020 as measurement amp?
Old 19th March 2012, 04:33 PM   #1
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
Default Lepai 2020 as measurement amp?
Does anyone know the response of this popular little Lepai? I'm considering using it for speaker measurement because it's:
Small;
Light;
mini jack input; and
Volume control;
But it's so cheap and all, I'm not sure it's suitable. Has to be linear. I wouldn't be using it for measurements much past 2.83V. Anything above that I'll drag out something tougher.
Thanks for any help.
Old 19th March 2012, 07:48 PM   #2
s3tup is offline s3tup
s3tup's Avatar
You can't connect anything beside speakers to it's output, because they are in BTL mode (no ground, differential). So this rolls-out impedance measurements, leaving just a FR/THD plots.
You'd better check "big opamp"-style circuits, such as the chipamp concept.
Old 19th March 2012, 08:22 PM   #3
Yup. I only want to be able to hook up speakers outside with this. That's why I want something small and portable. I just need to know if it's reliably flat? I don't have a clue about amplifiers
Old 19th March 2012, 08:52 PM   #4
Kjeldsen is offline Kjeldsen  Denmark
The chips it self have linear response from 30 Hz to 5000 Hz. 10 Hz is 0,5 dB down and 20.000 Hz also 0,5 dB down. I don't know if that is also the case with the Lepai, but they should be able to have similar characteristic's. You could also consider ready made pcb's. They are around 7-10$ incl. freight. I have seen Tripath TA2024, Yamaha YDA148 and others
Old 19th March 2012, 09:14 PM   #5
Thanks for this info. I might give it a try then. Better would be nice. But this would sure be convenient.
I'd try a ready made PCB, but honestly have no clue what I'm doing with amps. I was unsure buying a power supply for my Lepai let alone assembling a kit
Lepai 2020 as measurement amp?Hide this!Advertise here!
Which TA2020 amp? Topping TP20, Amp-03, or Lepai LP-2020 nkx1 Chip Amps 36 31st December 2013 12:43 PM
Mini ~$150 Ultimate Boom Box Lepai 2020 ++ ?? ph123 Construction Tips 17 20th December 2012 09:31 PM
SureTA-2024 Board integrated in Lepai LP-2020 - Quad Channel amp QT0815 Class D 3 13th February 2012 11:11 PM
Lepai LP-2020 mod to include sub out rziebro Class D 1 12th February 2011 04:01 PM
Copyright ©1999-2017 diyAudio
