Equipment & Tools From test equipment to hand tools
Please suggest a used scope that will...
Old 14th March 2012, 09:08 PM   #1
percy is offline percy  United States
Default Please suggest a used scope that will...
..allow me to transfer the captured/stored data of the waveform out to a computer where I can conduct spectrum analysis on it. I will be using a 3rd party spectrum analysis tool, unless the scope manufacturer has one already. Don’t care about the medium of transfer (usb, ethernet, memory card, serial, parallel, floppy…whatever as long as I can get the data to the computer)
I am not too worried about the number of channels or bandwidth and sample rate as long as its atleast a few tens of Mhz (say 60Mhz or more).
I do however want to get as much vertical resolution (dynamic range) as possible. I don’t mind using the scope gain and band limiting/filtering the input signal to achieve that.
Ofcourse, all this on a poor man's budget...
Old 15th March 2012, 04:34 PM   #2
PChi is offline PChi  United Kingdom
Hello,
I believe that most Digital Storage Oscillscopes are optimised for bandwidth so use 8 bit Analog to Digital converters so very limited dymanic range. Sometimes they have a 'high resolution' mode using oversampling with digital filtering (I also presume dithering), not to be entirely trusted.
LeCroy have the HRO range of 12 bit Oscilloscopes with wide bandwidth but definitely not budget.
Some other options are the Picoscope 4262 with 16 bit resolution and probably others.
There are what I like to call FFT boxes from HP and SRS and possibly others. I have used a couple of HP models with 100 kHz bandwidth and 16 bit resolution but they are expensive second hand though some of them must be about 20 years old so a gamble.
Please suggest a used scope that will...Hide this!Advertise here!
What do you guys suggest for me to do? tunks14 The Lounge 7 11th May 2011 05:15 PM
USB Scope - Real scope and not too expensive Algar_emi Equipment & Tools 11 17th March 2010 12:40 AM
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 10:59 PM
Can anyone suggest a design? jasonb84 Multi-Way 27 29th April 2004 12:49 AM
