Equipment & Tools From test equipment to hand tools
Vise Cleaning
Vise Cleaning
Old 8th March 2012, 10:49 PM   #1
Lavcat is offline Lavcat  United States
Lavcat's Avatar
Default Vise Cleaning
I just received a Palmgren mill vise, as part of my now nine month continuing saga to drill twelve holes. The Palmgren seems reasonably well made, though the milling on the ways is not as pretty as I might like, and the milled surfaces are not as smooth as on my Proxxon vise.
Here is my noob question: the vise is covered in grease and the instructions say to "Clean and remove all rust preventatives from all machined surfaces and spindle." They do not say how. I assume I should use some solvent, but what solvent should I use? Preferably something easy to find, cheap, nonexplosive and not foul smelling. I have on hand nail polish remover and alcohol, but that is about it.
Old 8th March 2012, 11:28 PM   #2
grimberg is offline grimberg  United States
grimberg's Avatar
Try this.
1 qt. Odorless Mineral Spirits-QKSP94005CA at The Home Depot
Old 8th March 2012, 11:31 PM   #3
KrankKall is offline KrankKall  United States
I just you Simple Green and paper towels....LOTS of paper towels.
Steve
Old 8th March 2012, 11:32 PM   #4
Speedskater is offline Speedskater  United States
Speedskater's Avatar
a] Awesome cleaner at one of the dollar stores.
b] An orange oil cleaner at the auto parts store.
c] WD-40
Kevin
Old 8th March 2012, 11:43 PM   #5
Lavcat's Avatar
Thanks. I had never heard of Simple Green. Would you use Simple Green on steel and cast iron that could rust? I'll see if I can find Simple Green or mineral spirits locally.
Old 8th March 2012, 11:49 PM   #6
I've never had a rusting problem with Simple Green?
But then again, almost nothing rusts in New Mexico either.
Steve
Old 9th March 2012, 01:56 AM   #7
Lavcat's Avatar
Went shopping for mineral spirits or Simple Green. Did not find either. Will try a different store tomorrow.
Old 9th March 2012, 02:44 AM   #8
grimberg's Avatar
Isn't there a Home Depot or Lowe's store near you?
Old 9th March 2012, 04:12 AM   #9
Lavcat's Avatar
There are both a Lowe's and a Home Depot several miles away. But this is a semi-rural area and I do not have a vehicle.
Edit: there used to be a well stocked local hardware store, but the chain stores put them out of business.
Old 9th March 2012, 04:22 AM   #10
Brian Oshman is offline Brian Oshman  United States
Brake cleaner.
Vise CleaningHide this!Advertise here!
Cleaning out the closet habsrock93 Swap Meet 32 28th February 2011 09:43 AM
Cleaning up jackinnj Construction Tips 5 22nd August 2009 01:37 AM
Best method for cleaning burningbushhifi Solid State 4 16th July 2009 10:30 PM
Cleaning out the Closet PassFan Swap Meet 0 24th December 2003 03:38 AM
Copyright ©1999-2017 diyAudio
