Equipment & Tools From test equipment to hand tools
Older signal generators worthwhile?
Old 1st March 2012, 07:25 AM   #11
Enzo is offline Enzo  United States
As long as they are not failed caps, they'll work. Subtle improvements that fancy caps MIGHT provide can wait until you have a chance to work with the units and determine your needs and how well these things meet them.
The circuits are a big oscillator, so anything that stops the oscillation will result in no output. Missing power supply voltages, dead tube, tube socket not making contact, freq selector switches dirty or oxidized and losing contact, lots of things.
Old 1st March 2012, 07:33 AM   #12
MOER is offline MOER  United States
Default Signal Generator
We have Heathkits IG18 in stock, used but in good working order $50 each.
Other meters and scopes as well
zedaudio@aol.com
Steve
Old 1st March 2012, 11:14 AM   #13
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by DJNUBZ View Post
If I wanted to recap either of these is there any problem with using cheap modern caps as long as they were of the proper V rating?
If you look inside a high quality oscillator like a Krohn-Hite, Tektronix or HP you'll see that the caps are polypropylene, polycarbonate or silver mica, and they were probably selected for precise values.
Of course, it always depends upon what outcome you seek, but there may be no point to replacing the caps with inexpensive ones since results may be worse.
Power supply is a different matter. You might have gotten lucky with electrolytics which haven't dried out.
Old 1st March 2012, 01:29 PM   #14
head_unit is offline head_unit  United States
I just found a guy selling a function generator in the area. Is that able to do the same job?
If you mean one of those skinny ones with sine/square/triangle, that is the class of equipment we found to have higher distortion.
Now, that was some time ago. Maybe they're better today? You can always Google the model number and check out the specs. For audio work you want the sine distortion as 0.0xxxx%, because under controlled circumstances we could definitely hear around 0.something percent (0.3%? 0.1%? I forget exactly)
Old 7th March 2012, 01:49 AM   #15
BFNY is offline BFNY  United States
My experience is to not buy any tube based generators, except maybe the HP 200CD if you are into vintage test gear. Except the HP 200CD, these are mostly unreliable, drift, and for me, more trouble than they are worth.
I also would not buy a function generator to do distortion measurements. These are not clean - 35dB harmonics is typical. Almost every "common" generator you can buy is horrible for distortion, very few better than -50dB.
You need to get a specialized low distortion audio oriented generator, which are rare and pricey, to get better specs than a test tone CD and a CD player, which should easily get you better than -90dB harmonics.
The one built into the HP339A is one, so is the Tek SG-505 both can do -110dB or better.
You can buy the test tone CD, or make your own with free software. Or use a PC and soundcard.
Old 9th March 2012, 07:23 PM   #16
cyclecamper is offline cyclecamper  United States
Speaking of signal generators...my Behringer digital EQ also made sine, white, pink. When I put a sine into my Newform Ribbons, I was quite shocked at how much the "timbre" changed as I turned up the volume. At low volumes, the sine sounded pure, but as I increased it there was a noticeable change as some raspiness was introduced. And this was not at really extreme levels. I was putting one channel of my amps into each of the 4 ribbons (really narrow mono-polar planar dynamics) so I doubt the amps were anywhere near clipping, though they may have been going out of class a into class b? Someone who shall remain unnamed implied that it was my ears distorting and not the speakers. I should have taken some sound level measurements so I could discuss this intelligently.
Maybe this is just testimony that efficient speakers really do get louder before they distort (these ribbons are NOT very efficient compared to many other high-frequency transducers nor do they really put out a whole lot).
BTW Some "function generators" are meant more for making a clock signal...
Old 9th March 2012, 11:38 PM   #17
Speedskater is offline Speedskater  United States
Speedskater's Avatar
How could an HP 200CD come up in two different forums on the same day? See post #29 and check the linked picture.
Well Duh! - Page 3
Kevin
Old 10th March 2012, 12:07 AM   #18
Conrad Hoffman is offline Conrad Hoffman  United States
The old HP tube sine wave generators have served many very well for a long time. That's what they used in the old traveling McIntosh amplifier clinics. Starting out, I wouldn't hesitate to have one. They're not hard to service. They turn up with regularity at hamfests for $25 or so. A slightly newer HP 204 is more compact and doesn't use tubes. Recommended, but harder to service because it's smaller and more crowded. Probably more reliable though. A working General Radio 1310 is a great little generator, but it controls the amplitude with an unobtainable vacuum thermistor, many of which have gone bad. I think it also uses a Nuvistor. I like Waveteks, but I've found many of them need service by now, recaps and sometimes even new IC sockets. They aren't that difficult if you have some experience, but can be a real headache if you don't. OTOH, you'll learn a lot if you have to work on one. They also derive their sine from a triangle, so have that little point on the peak and resulting higher distortion. My favorite is the 185 because it sweeps and has separate knobs for each end of the sweep. The perfect generator hasn't been invented. If you have a scope, it's not that hard to build a very low THD one from scratch using Jim Williams notes from Linear Technology.
I may be barking up the wrong tree, but at least I'm barking!
Old 10th March 2012, 01:58 AM   #19
gootee is offline gootee  United States
Yeah, if you have more time than money then making your own could be very rewarding.
To get the sine even more pure (or even to derive a fairly-decent sine from a triangle), you could also add a tracking post-filter. There's a trick I came up with that I thought was pretty clever: The tracking filter used led-->photocell devices as current-controlled resistors, to change the filter stages' cutoff frequencies. To make it track to just above the fundamental frequency (so it would attenuate the harmonics to the maximum extent), I just used a peak detector feedback loop that automatically adjusted the cutoff frequencies up or down until the output's peak level was at a predetermined value (some fraction of the input amplitude, which was close to fixed). That way, the filter didn't have to "know" anything. It was extremely simple and worked pretty well, as long as you were willing to wait a few seconds when switching frequencies.
You can also make a triangle/ramp/square generator very easily, with two opamps and some capacitors and resistors. There are actually many ways to make those.
Older signal generators worthwhile?Hide this!Advertise here!
Clean used function generators? dgta Equipment & Tools 4 3rd June 2011 06:51 PM
Function Generators airboss Equipment & Tools 11 9th June 2010 05:06 PM
Sweep Generators yldouright Swap Meet 1 29th June 2003 01:53 PM
scopes, generators, meters - what do you use? dorkus Equipment & Tools 1 24th April 2002 08:52 PM
scopes, generators, meters - what do you use? dorkus Solid State 0 24th April 2002 06:14 AM
Copyright ©1999-2017 diyAudio
