Equipment & Tools From test equipment to hand tools
Solder Wick
Solder Wick
Old 5th February 2012, 11:33 PM   #1
dennismiller55 is offline dennismiller55  United States
dennismiller55's Avatar
Default Solder Wick
I am currently using GootWick. It has worked well for me. I am running shy and plan to buy some more online. If you buy it out of China (yikes) it is fairly low cost.
What is meant by the term "No Clean"?
Any recommendations?
Old 5th February 2012, 11:54 PM   #2
cocolino is offline cocolino  Germany
cocolino's Avatar
Default "No Clean"
Does this wick contain flux?
If so "no clean" refers to the flux and means You don`t have to clean flux residuals off the board. Some kinds of flux act corrosive and can harm the PCB or electronic components. Flux residues can also be slightly conductive and disturb functionality of a sensitive electronic circuit.
However, I`d clean flux residue always, even "no-clean", just to be on the safe side or be it for cosmetic reasons only.
Christoph
STEAL the BEST - INVENT the REST
Old 6th February 2012, 03:40 AM   #3
yajnaS is offline yajnaS  India
Stick with goot.
I've tried the other stuff and it doesn't work anywhere nearly as well. (I think the difference is the goot wick is a finer mesh and has a better flux)
"no clean" simply means it has a very mild flux that can be left on the PCB. It doesn't work as well. Unless you're a big workshop that will save $$ by not cleaning, I think you should avoid the "no clean" variety. PCBs should always be cleaned with alcohol after any work.
Old 6th February 2012, 06:59 AM   #4
WSJ is offline WSJ  United States
WSJ's Avatar
I learned how to make Solder Wick from its inventor at AMPEX in 1969.
You can make it for a fraction of the cost. After soaking the braid
in flux, dry it with a heat gun. Use the empty Solder-Wick spools to keep it fresh.
3/32" x 100 ft. Flat Tinned Copper Braid is under $25, this may not be the fine braid needed for good wicking.
Minute Man Electronics Tinned Copper Flat & Round Braid
Liquid flux, $9
Liquid Solder Flux, 2 oz. | 20-1100 (201100) | Distributed By MCM
Wayne
Old 11th February 2012, 12:36 AM   #5
amc184 is offline amc184  New Zealand
amc184's Avatar
Solder Wick
Don't buy Goot wick from China directly. The genuine Goot wick is great, some of the most effective solder wick I've ever used. However, I ordered a few rolls from a China based seller on eBay and what turned up looked exactly like the real thing but simply didn't work; solder would not wick up the braid. I'm guessing that it used an inferior flux or something like that.
Geniune Goot wick is a bit on the expensive side for me, I now use Edsyn 'Soldasip' which seems to be just as good. Besides this, I hardly use wick after getting a good solder sucker, an Edsyn SS750LS.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 11th February 2012, 12:58 AM   #6
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
I usually add flux, when using solder braid. It speeds up work and improves the overall result.
regards
Old 11th February 2012, 01:10 AM   #7
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
GOOT is a Japanese brand (Taiyo Electric Ind.). If it comes from China it may not be authentic.
Old 11th February 2012, 11:21 AM   #8
Thanks everyone for the great insight. You do have to be on guard when puchasing anything from china. The old saying: You get what you pay for. So I will stick with Goot.
Old 11th February 2012, 03:35 PM   #9
ChocoHolic is offline ChocoHolic  Germany
After some low cost trials... - I went back to soder-wick.
Saving five EUR per year was simply not worth the worries other types had caused.
Old 19th March 2012, 08:36 PM   #10
Simon B is offline Simon B  United Kingdom
I just strip some multi-strand salvaged from old mains leads, dipped in a little flux. Works great, much better capillary action than a braid, free too, no part number required.
Solder WickHide this!Advertise here!
Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? mbl Analogue Source 23 24th November 2010 04:13 PM
what kind of desoldering wick to buy? spooney Car Audio 1 26th September 2007 12:33 AM
Best solder to use rtarbell Parts 4 20th November 2005 02:05 AM
what solder should be used ?? kambule Parts 27 8th August 2005 02:16 PM
can I solder on this? Duck-Twacy Multi-Way 9 24th February 2004 01:46 PM
