Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 29th November 2012, 02:54 AM   #911
davada is offline davada  Canada
Default 339a Disto
While I've got this apart.
Any Ideas?
David.
Old 29th November 2012, 03:03 AM   #912
Originally Posted by 1audio View Post
Could it be the same phenomena that affects the AGC in the oscillator? Ripple etc. on the amplitude/phase controls?
I'll have a look and post some data.
David.
Old 29th November 2012, 03:17 AM   #913
Default TP1 and TP2 error signals
This is TP1 and TP2 error signals off the phase and level detectors.
This is what is sent to the LDR's
David.
Old 29th November 2012, 03:30 AM   #914
Frex is offline Frex  France
Hello davada,
Could you say what FFT software do you use for your screenshot ?
Regards.
Frex
Old 29th November 2012, 03:51 AM   #915
Originally Posted by Frex View Post
Hello davada,
Regards.
Frex
Hi Flex,
I don't know that I can at this time because I'm involved with the beta test program for the hardware and software. That's why I obscured the name. Its not ready for release but I will ask if I can share what it is.
It is very near an EMU0204 and ARTA in performance.
David.
David.
Old 29th November 2012, 03:57 AM   #916
Ok, thank you!
I follow from many years all of available FFT softwares, and i didn't recognized the screenshot .. I will be interesting to know if it's a new software if it's a commercial product (or not?).
Regards.
Frex
Old 29th November 2012, 04:17 AM   #917
Ok, thank you!
Regards.
Frex
It is geared to be a commercial product but priced in the same range as an EMU0204 and a licensed copy of ARTA. I think it will be tailored for audio and production line testing.
David.
David.
Old 29th November 2012, 04:24 AM   #918
Ok, thank you!
Regards.
Frex
This is the control panel.
David.
Old 29th November 2012, 05:08 AM   #919
1audio is offline 1audio  United States
It seems unlikely that those signals could be causing the distortion in the output. But their presence at all suggests the distortion is hiding under some rock nearby. It could be as simple as the harmonics from the level detector getting back in via a shared ground. Not an issue if you stop at -80 dB. Big issue if you are going for below -100 dB.
I would next try making the integrating caps on the level detectors larger and see if the harmonics increase or decrease. Those are the obvious nonlinear stage and driving them harder will show if they are coupling into the rest of the circuit.
The other candidate would be the LDR's themselves. Reading this thread DIYHiFi.org • View topic - LDR as a volume control suggests the LDR's in the 339 would be in the 2% THD generation. The Silonex parts would be substantially better. Looking at Nelson Pass's measurements you should keep the voltage across the LDR's below .2V or less. If they are the cause then a 20 dB improvement would be immediately visible. Perhaps you can look differentially across the LDR's in the 339?
Demian Martin
Product Design Services
Old 29th November 2012, 09:11 AM   #920
coluke is offline coluke  Italy
Wow - recognized it! Seen a few demo videos a couple of days ago, and discovered myself wondering about release date. It looks great (particularly the H/W), and seems very promising indeed (although I'd add a few more FFT windows...) - need another beta tester?
L.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
